Hey guys, my gtr came with a nismo speedo which is redline after 8000, im pretty sure this is definitely not the same redline for a stock dash gtr.....is it more close to 7000?.....im just wondering cause id like to know the safe revs for a stock internal rb26 motor like mine....ive revved it past or close to 7500 once, but wont do it again...right now i rev to ~7000 or under...i want reliability more than anything as this is a new drop in motor which is extremely healthy.
thanks...
I doubt you'd be making power at 8000rpm, so why take it that far? :D
Yeah i wont be, its just that i sometimes go over 7000 when driving hard without knowing it...never 8000 or higher though...is there a way to cut out after say 7500 so i dont do any damage to my car?...maybe when i get it tuned or something?
any aftermarket ECU will have a way of setting the rev limit
on my old internally stock 32 GT-R, my tuner set the hard-cut to 8200
at the track, i would change at 7 where possible, but let it run to 7500 in some corners where needed. keeping the revs lower is a good way to keep the oil temperature from going critical on engines without aftermarket oil coolers, too.
Stock r32 GTR has a YELLOW line at 7500 and a RED line at 8000, no point reving past 7500 as you wont be making any more power and the pull in the following gear may even be stronger as you will be back in the meat of the tourque curve
Unless you have 2530's and poncams and have to rev to 8000+. Some guys don't go above 6k!!! Good old oil pump drives are too narrow on the early 32's and thats part of the reason why 7500-8000 redline.
Thanks, yeah r34 n1 turbos, so 7000 is a good limit to set...is it good practice to tune my car with a rev - cut at say 7000 or just over in my case???
In my situaiton, sometimes when im driving the car hard i drive over 7k sligtly, not alot though, but now im getting used to learning to shift up faster:)
what you have to watch is where in the power band the engine will be when you change gear, you dont want the next gear to fallout of the meat of the power/tourque curve.
What you want is the torque output of the engine multiplied by the transmission ratio in the higher gear to equal that for the lower gear you are about to change out of. That is the correct point to change up.
Ofcourse road car gear ratios being what they are sometimes that point is beyond the redline.
And yes, 7500rpm is as good a number as any, but the RB26 will take occasional bursts to 8000rpm without expensive damage. Just don't do it all the time. The other thing to note is the tachos aren't very accurate, usually reading a little conservative, ie high.
Oh and is you want to try the 11,000rpm thing make sure you video it. :P
Edited by djr81
  • 2 months later...
Thanks everyone, just got my car tuned, and it doesnt make more power after 7000, so i was thinking 7300rpm rev cut, would that be safe, what happens if i reach rev cut, and does it do damage to the motor (surely its better than over revving when you are going hard...)
Also, the n1's run out of punch after 6500-7000 anyway...
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
