Item: 1992 eg civic 1.5(note comes with 15 alloys well be needing new tires)
Website: Trademe.co.nz
Item Condition: mint
Reason for Selling: wanting a turbd
Price and Payment Conditions: $7500 OR KEEN ON SWAPS!!! ONLY (teg,180sx,ae86,corolla gt(4age),gtir,gtx,bfmr,starlet gt)
NOTE NO daewoo,hyundai ect...
Extra Info: 1992 civic 1.5 non-vtec twin carb(not the 1.3 pussie &*@#), big bore muffler, 155,000ks only!!! 5speed manual new rwc and reg,pionner head unit,sunroof,REGASSED AC!!,Brand new oil(castrol magnatec and new oil filter),Just spent $250 keeping the cooling system in perfect working order
https://www.sau.com.au/forums/topic/209512-92-eg2-civic/
  • 3 weeks later...
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
