thats exactly how a boost gauge works mate....below 0 is vacuum up to 0...then anything above that is displaying the amount of boost being used.....i have aftermarket gauge in psi and thats a lot more accurate from what i have found to stock gauges
is it normal that b4 i start the car pic1 turbo gauge showing 0- zero
and after car is running its going down pic2 but only to -0.6
month ago it was before i start a car in -1 and after -1 now it changed
is it a problem ??
thanks guys
Like most have said, it's normal for it to sit at 0 (atmospheric) when the engine is off, and for it to go negative when idle (the motion of the engine literally sucks air into it).
However, if the amount it goes down has changed and you haven't done changed anything (pod filter, boost controller etc), then you might have a leak. Does it still make the same maximum boost? (stock on the 34 is just over 3/4, or half way between 0 - 1) Does it hold that boost if you hold your foot down?
i will check it and let u know but i think i yes its hold that boost.
i recently bought my skyline and i think its time to go to mechanic for inspection
will check my boost and let u know
thanks
just check it
working okay
its in 3/4 when hold foot down
thanks gosh no leaking
P.S. noticed another strange thing, sometimes boost gauge is stopping working (like the engine is turn off) anybody no how can i fix it ?? is it wire or gauge or what
thanks
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
