If you are doing a stay-at-home type bbq and beer, with b00bies etc, then I can thoroughly recommend brewing the beer yourself at one of these brew on premises places. I used one last year for a bucks party and it went down a treat! Most places will hire you keg setups, and you just tell every one to bring their own mug - less clean up and you save on glass hire :D
https://www.sau.com.au/forums/topic/209540-bucks-night/#findComment-3706236
Wheelie Bin,
Cut hole for his head on the front of it, holes for his arms on the sides, lock him in it and take him to the strippers and to pub and clubs....... Happened to me and I loved it (Was In Sydney at the time)
https://www.sau.com.au/forums/topic/209540-bucks-night/#findComment-3707125
Wheelie Bin,
Pictures? Where did you piss? lol!
https://www.sau.com.au/forums/topic/209540-bucks-night/#findComment-3707185
Book a table at a nice restaraunt, everyone wears a tuxedo, order great food and wine and ....stuff it, BBQ, eski full of coldies, skimpies to serve and strippers OR you could hire a boat and take the party to the water, that way the party finishes when its time and no noise problems...book a bus to get everyone home in one piece
https://www.sau.com.au/forums/topic/209540-bucks-night/#findComment-3709831
have been to afew bbq boobs and beer and its always a good night
for my brothers we were a little more refined we hired a boat and cruised the river enjoying bbq several kegs from little creatures and poker
boobs would have made it better but was still good fun
if your going with the barbie at home idea i sugest 1/2 skimpies to serve drinks with a striper later in the night
nothing better than a cold one served by a nice set followed by a show lol
Edited by GWP021
https://www.sau.com.au/forums/topic/209540-bucks-night/#findComment-3714396
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
