watched a performance dvd the other week and there was a performance/race car on it that had a large intercooler in the back with twin thermo/cooling fans pulling air through intercooler.
i was thinking it is a good idea because it will always have cool air flowing through it.
when using fmic setup air gets forced into fmic while in motion, but if front mount has cooling fan pulling air through it would make intercooler more effective and efficiant...
saying all this if this is right, would putting a fan behind my fmic (pulling) create more of a gain? especially at standstill when intercooler is not getting air forced into it.
any info will be great or if anyone else has any other ideas will be a bonus.
4drftn
yeah sh@un is right, no gains to be had
it was probably a radiator/cooler combo at the rear because they'd run out of room at the front, the fans were probably just to push air through because it'd be lacking the wind you get from the front of the car
spend a little time making some foam air guides (or a nice metal guide if you have the skills with the material) for between the intercooler and radiator so the air doesn't 'spill' making the standard fan setup work more efficiently.
sorry i may have not explained myself well, but i am already running viscous fan+12inch cooling fan infont of my radiator pushing air into it...
now... what im actually trying to find out is benifits from having a pulling fan on the back of an intercooler or fmic, in other words trying to get more air and cooler air into intercooler to maybe produce more power etc.
sorry for the confusion
4drftn
i have seen this done, it was set up to come on when the intake temps go up to a certain temp, only really usefull and low speeds or stopped when there is not enough air flow over the fmic.
Id start with measuring your actual intake temps, take a common, do some plots over time, otherwise your just faping into a carrot cake.
Water spray while standstill i find isn't soo effective (well not as much as Id want it to be) The water itself isn't cooling the IC, its the latent heat thats absorbed in the state change from liquid to gas (evaporation) Hence, without the air moving over it, kinda hindered.
Thermos and a water setup could work well me thinks, if you really need to prevent heat soak while standstill.
If state change heat absorption is your game, iv always been interested in those C02 IC sprayers. C02 is dirt cheap, and in 30s can have a ice covered IC when dead still. I had almost ordered one, but a change meant it wouldn't work with my setup.
Thinking aloud :/
EDIT: After getting some base figures, first try air guides first as mentioned - a must.
Edited by GeeTR
When the intercooler is working hardest is when you're in motion- meaning there's plenty of airflow already over the cooler.
water-->air intercooler would be the best upgrade, esp. for heatsoak issues, but it's not exactly a simple bolt-on upgrade like a regular fmic.
Airguides ftw, maximise airflow to the cooler. In the meantime you might want to put a fan behind the fmic and do some tests with a thermometer-type tool and see if the fan makes a difference to charge temps and cooler heatsoak temps.
Air -> Water IC's (what i think you meant) still needs a heat exchanger (rad like)
People use thermos on those heat exchangers... thermos on a Air -> Air should work just well maybe?
Try it, let us know :/
Edited by GeeTR
i think i most definatly will give it a go... aswell as air guides for maximum gain. does anyone have any pictures of an airguide they have customly made for there setup?
also how would i go about measuring the air intake temp/amount? will it be in ECU data?, i have a microtech LT-8 ECU, should i be able to access that sort of info?
cheers
Always wondered if 12 volt peltiers would be the go. Peltier runs on electricity gets hot one side and very cold other side smaller ones can cool cpu in computer so i imagine larger ones could be utilised in aiding to cool an fmic? just a thought
The short answer to this is : don't waste your time.
A properly ducted intercooler will take advantage of the high pressure built up at the front of the car when travelling at any reasonable speed.
This pressure build up will be more than any fan is capable of providing.
Hence installing such a fan is a waste of time.
But:
If your car is a GT-R it already has a fan installed to push air through the radiator. You can hear it click on when the car is sat idling on a hot day.
It is far, far easier to plumb in some water misting to spray the intercooler when the inlet temps go above a certain threshold. Why don't you look into that?
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
    • A 180SX has a much better look than a FD. The roofline is far superior being a fastback. It's popups look better. In a world where we all subconsciously add a little bit of low, and wheels of our preference, it's just more handsome than the FD is. The FD just looks 'bubbly' in comparison. It can come down to preference, sure. But "The FD is the BEST looking (on appearances alone) 90's JDM car without question?" Nah. Plenty of questions lol. I could think of 8 cars I think look fundamentally better, and probably a handful of ones that look about on par with a FD. (like say a SW20 MR2) I feel people like/overrate the FD because of it's mythicality/rarity, its rotary and it's unpredictable nature. It probably drives great, you can stuff a ton of tyre under there, has a unique sound, light as hell. I feel that people reading this thinking "YOU CANT RATE A 180 ABOVE A FD BECAUSE A 180 IS A CHEAP DRIFT BUCKET" prove the point about bias as to what the car represents, moreso than how it actually looks.. I feel the 80's boxy/squared off look is becoming better looking due to time, and 90's melted soap bar aesthetics have not aged well. (yet?) And this thread is purely about looks :p
    • A red or yellow S15 wins my vote, Ack that it just scraps in with the 90's cars theme, but they are great looking little sports car Next would be a A80 Supra (pre face lift), whilst the A80 has its own issues, I feel is the best looking larger GT car As for the FD, "I" feel that the reason it triggers me in a non-positve way when looking at one, is like looking at a high maintenance pretty girl who you know is mentally unstable and likely to explode for no apparent reason
