THX paulr33 give me that information.. :)
REF TO THIS http://paulr33.skylinesaustralia.com/docs/...erfc-faq.htm#70
AS TOPIC WHICH PFC CONTROLER TO SUIT RB20DET??
FCC NT First generation to suit Nissan ?
FCC FN Second generation to suit Nissan ?
DOES ANYONE USING AP ENGINEEING PWC FOR THEIR RB20DET... ?
CAN SOMEONE TELL ME WHICH CONTROL TO SUIT??
https://www.sau.com.au/forums/topic/209557-power-fc-controler-for-rb20det-a31/
Back of the hand comander: FCC2 NT010-00443
I won't be starting the car for a day or so, when I do I will check what version it is for you
Is the above version hand commander right for the PFC I have Paul?
It works fine with no issues etc - its just that you said it should be N001
I know the FCC2 refers to a Version 2 - but whats the go with the NT010-00443
yeah FCC NT or FCC NT2 is the older style hand controller
this was for nissan generic before they started shipping them as batch FC + HC
but you can't buy FCC NT new anymore as they don't make it
they make
FCC N001
or
FCC X001
N001 is the older style nissan hand controller - this should work - their serial is usually like RB20 or RB25 or RB26 (note its the actual engine code)
X001 is the newer style hand controller - for users who have the bundle style PFC - their serial is usually like ECR33 (note it changed to the actual car code) or GTR33-L (BNCR33 l-jetro)
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
