Guest Peewee
Hey guys i have an R32 GTS-4 for sale
It has all the usuall trimmings like
ABS
Airconditioning
Four wheel steering (hicas)
Four wheel Drive
Power everything i.e windows,mirrors, etc etc
The car is painted in S15 blue inside and out
Plus a full 93 suede interior with R33 GTR drivers seat
Cd player 6 X 9's andfront splits
Aftermarket gear knob
Bosch 044 fuel pump
1.5l fuel swirl pot
super heavy duty daiken 5 puk brass button clutch (still very driveable)
Huge front mount intercooler with custom piping
Haltech afetrmarket ECU
Alluminium Radiator
Alluminium Oil catch can
Aftermarket coils With 10mm spark plug leads
Metal Headgasket in engine 1.2mm
3" pod air filter
Custom blow off valve
Full 3" exhaust from turbo back and high flow cat with stainless barrel muffler
Adjustable upper rear control arms (cusco)
Kings spring 2" lowered
18" wheels with brand new tyres
Nolathane castor rod bushes
Brand new timing belt and water pump
car has travelled 75 000 kms
Car is in sydney
If anyone is interested please email or pm me.
Or just call my mobile 0407010781
https://www.sau.com.au/forums/topic/20956-perfect-r32-gts-4-for-sale/
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
