  • Replies 40
Posted Images
i have a new petrol navara, great tow car power and speed wise good for 150 kph odd with trailer behind! lol
but absolutely sh!t house for fuel consumption! :D
why'd you buy a petrol one? i assume your talking about the d40 models?
my old man had a diesal d40. 2.5ltr 4 cylinder diesal. GREAT car seeing over 650 from a tank when driving in the city. fuel consumption can go down below the 9 ltr per 100km average on highway driving. consumption barely changed an with my old sil80 and a trailer you almost would notice it was there.
the old saying goes if your gonna tow go diesel
man, some good replys. thats given me some good ideas. i hear u gary re: the 4wd is needed in muddy situations. im still looking arround though. the ordfay sounds like the best option so far.
it seems as though the 2.6 petrol mazda bravo wont cut the mustard without some extra heavy duty work done to the rear end. not to mention load bareing tyres. found out it was easy enough to go out and buy a 2.5 tonne tow bar and assembly 2nd hand easily enough for the bravo though.
i was being told by a hard to understand serbian fellow at work today that the lpg systems on cars need to have checkups regularly. he says that once a year isnt good enough and that most people dont even do it that often. he's an ex taxi driver. he said that their cars were inspected on a 3 month basis. i dont know how true that story is re: road cars.
how often do AU fords need a rebuild? id expect them to go to 500,000klm no probs with regular oil changes and being treated right. all of the ones in my price range are at the 200,000klm mark.
yeah dunc go diesel ! we dont see anymore than 300/350 kay when towing on 80 litre tank!
spencer and I use his navara STR turbo diesel. it is awesome to tow with. it's a 4 door with 5 usable seats, has a hard top for the tray (down side is limits storage badly, upside is it locks) and has towed the GT3 cup car, my GTR, his group NC Alfa and dozens and dozens of others over the last couple of years. it even fit my big ass sony LCD tv in the back (just!). also being turbo diesel we cranked up the boost a bit and got a chip for it too. goes pretty well now but fuel consumption is not exactly stellar. but it can tow at a pretty rapid pace easy well past 110. :banana: chirps seconds too.
got the petrol , because it goes like a rocket and i can deal with the fuel economy.
also i didnt like the noisy diesel and didnt want a manual (the auto diesel was twice as noisy, always reving on the convertor)
I've towed most of my working life and tried them all, Utes are ok but there is the afore mentioned security and lack of passenger room. Landcruisers are good too, Just not as bombproof as toyota would have you believe.
The best tow vehicle I have used and still use is the Nissan patrol.
I have owned the 3 litre variant, the 2.8 litre td jobbie, the 4.2 petrol and my current worker is the 4.8 petrol.
They all performed a stellar job, even the smaller engined units worked well above their weight and both ran up many hundreds of thousands of kays before i moved them on.
The 4.8 laughs at any load I care to pull with it. It likes a drink but that has been minimised with some custom pipework. an ecu and a dyno. Its big, comfy. power to burn and refuses to fail. (it will also tow a loaded car trailer faster than that too Russ :D )
The other advantage to using 4b's is the weight over the front axle. rwd utes etc are ok but still subject to rock steer even on a well set up balanced trailer package. You start hitting some undulating road and the weight transfer to and from the front of the tow vehicle is far more pronounced in the rwd. The heavier fronted 4wd virtually eliminate this phenomina.
The only other option that I can see is the even bigger ford/chev pickup truck style vehicles but cost becomes a real limiting factor there.
I have the 2200kg tow kit put onto my VZ V6 commadore sedan and it tows great, probally does abot 15ltrs/100klms with the car on and can sit on 110klm/h very easily.
Even going up Mooney Mooney it sits on 100klm although reving the guts out of it.
Big boot for the tool box and jack bt and pieces and luggage, rear seat for the passengers and usally put spare wheels in the car that is being towed.
I used to have a VS commadore V6 which also did a stellar job but recomend getting the tow kit with the bags which i have in the VZ as you can lift the rear of the car up so it is not dragging it's arse on the ground.
You could pick up a second hand commadore for fairly cheap so maybe this is an option (could go a station wagon if you want).
Matt
if you get a navara, dont get one of the newer shape. theyre faarked
if anything, get a D22, nissan brought them back because the new was no good
new D22 runs the patrol 3L diesel
or something like a patrol, you can get them in 4.2L turbo diesel (ST-6 i think?)
what wrong with the d40 model (new shape) i know of at least 3 (one being my parent's that i drive regulary) that haven't had any real issues at all? all are used for towing and four wheel driving and just general town driving?
thier only downfall is they are pretty big and lack of ground clearance. but you don't buy a new 4wd to go do harcore four wheel driving do you
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
