  • Replies 65
Posted Images
  • 3 weeks later...
Would you consider 100 bux for just the rear bar. Could pick up in early May.
yerp no probs
what color was the car mate.? pm me your number if its white. need many parts
yes its white! hit me up on here with what u need
also for Sale
18x 7.5 maybe 8 unsure, 4 stud pretty normal offsets!
front tyres around 60% rears would be just under legal
heres a pic of the same wheels
after 700o.n.o will need some stockys and price will be reduced with them
greedy style plenum with 80mm billet throttle body to suit RB25 (adapter plate has already been welded on so t/b bolts straight on) $450
White P1 buddy clubs 5x 114.3 17x 8 17x 9 (guessing) goodyear eagle F1's 235 fronts bridgtone potenza re001 adrenilans 255 rear, tyres are pretty much brand new, very good cond need a clean came off a r33, i did want to keep these but dont clear the struts on my s13 (yes i have coil overs but car is going to regency) $1750
i will need at least a pair if 5 stud wheels for my car to roll around on haha
Edited by shy_s6
still interested in rear bumper cover if u still have it.
Don't need the pods or reo tho.
I'll be up that way on the 17th May.
If u need I can bring tools and take it off if you like :laugh:
I'll PM u later for some details etc.
i have tools bud, im getting stuck into my sil project but if i find time ill get it off :D
i need the following.. in white only R33 S2..... Del to melb
Price plz
front bar ( any except s1 bar) + grill
s2 bonnet
rhs s2 head light
rhs lower control arm.
rhs front guard
rhs side skirt
rhs door - (bare) - i have one with a big dint which i will swap you to avoid removing the insides.
rear bar ( any )
lhs rear tail light
rear center thing in between the light.
boot and spoiler. s2
Price plz
front bar ( any except s1 bar) + grill broken
s2 bonnet bent
rhs s2 head light broken
rhs lower control arm. i have
rhs front guard i have
rhs side skirt i have but selling as a pair
rhs door - (bare) - i have one with a big dint which i will swap you to avoid removing the insides. i have
rear bar ( any ) sold pending payment
lhs rear tail light i have
rear center thing in between the light. sold
boot and spoiler. s2 i have
delv will be a prick for the bigger items i think bud, but if you want to sus it from your end go ahead
  • 3 weeks later...
  • 1 year later...
all prices very negotiable guys may sell complete wreck soon as i have most the bits i need!!
need a aerial and some air con bits and probally some other stuff, still parting out?
  • 4 weeks later...
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
