hey guys just wondering if anyone knows a good place in aus where i could purchase a decent resonator that isnt the size of a football field ( car sits very low dont wanna rip it off )
my friend has a resonator cut out of a blitz nur spec exhaust and its a perfect size/shape kinda looks like a magic cat but yeah, just wondering if anyone knows where to find something like this...
https://www.sau.com.au/forums/topic/209604-exhaust-drone/
It really sux because im running a larger turbo with bigger exhaust housing the whole note of the car is droney and annoying
yet when it had the stock turbo it was so much quieter... when you mean muffler you mean the cannon on the rear or a muffler half way between the exhaust
https://www.sau.com.au/forums/topic/209604-exhaust-drone/#findComment-3705892
I'm running a 3.5 inch turbo back, and its dead quiet with a 5inch canon at the back....
probably more quieter than a stock SS
Im having the same problem with the drone of the rb26 with a 1.06 housing. Ive got a 3.5 inch trust TR drag exhaust, and its really loud.
How is your 3.5 inch exhaust so quiet? What mufflers do you have on it?
I dont really want to restrict too much though, as its cost a lot to get 350rwkw!
Shaun.
https://www.sau.com.au/forums/topic/209604-exhaust-drone/#findComment-3707075
If your car is 70mm off the ground, then why don't you get it up to LEGAL limit.
then fit the proper mid muffler and make the sound LEGAL too.
but I guess it won't look as fat, PHAT, PH4T or what ever hektik word you want to call it.
because stock height doesnt interest me and looks fkn disgusting :)
https://www.sau.com.au/forums/topic/209604-exhaust-drone/#findComment-3707319
Shaun.
orginally it was a ST May's exhaust, but I've chopped off the rear muffler and replaced it with a HKS Super Dragger, but still retain the st may 3.5 inch mid muffler.
You can have a full conversation and listen to music with the windows up and can't even hear the exhaust on the highway, that's until plant it. :P
Edited by johnnilicte
https://www.sau.com.au/forums/topic/209604-exhaust-drone/#findComment-3707761
  • 3 weeks later...
  • 4 years later...
hey guys i got a trial titanium exhuast yesterday and fitted it, its 3" cat back with a resonator and a cannon, sounds amazing except for 2700-3100rpm.....DRONE!!
anybody know what i can do to stop this?
http://www.skylinesaustralia.com/forums/topic/414728-titanium-exhaust-drone/page__p__6649596#entry6649596
cheers
https://www.sau.com.au/forums/topic/209604-exhaust-drone/#findComment-6649666
Does anyone have underneath pics of the mid and rear muffler space of an R33 . I believe they don't have a lot of space and it would be good to know how big the oval mufflers can be . My exhaust is some sort of Nismo the car came from Japan with , pretty quiet and I'm curious to know what they've done to shut it up . I think most Jap exhausts would be 80mm because they can't replicate (metricate) 3"/76.2mm .
A .
https://www.sau.com.au/forums/topic/209604-exhaust-drone/#findComment-6652096
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
