hey guys just got my car from the panel shop,
and it wont start, there is no power going to the fuel pump
i no the fuel pump works cause when i feed cables direct from the battery you can here it buzz
iv tested the fuel relay and that works, as well as the fuel fuse, i dont no what else to check.
the fuel pump wont even prime when ignition is switched on
some please help me
https://www.sau.com.au/forums/topic/209608-fuel-pump-problems/
^^ yup, so its clicking, which means its been triggered correctly.
Rem a relay is a switch, thats turned on/off with a a small current.
The small current, or trigger, is working... so its switching.. but is there INPUT voltage to it?
As in, is the power that will be sent to the pump, present at the relay? Sorry if my explanation is shite, im tired :/
EDIT: Re-read your post.. sorry.
Ok, well if its switching, and you have power to IT.. but no power at pump... couldnt there not be a break / aftermarket dead fuse between those points?
Edited by GeeTR
