hi sau members :D
i just bout this car not long ago nd not sure wot these rims are
there 245 at the back so got sum rubber on them
1 of the guys from jaxs tires recon there 2000grand just rims
is that true? aprently there import trust rims but didnt no they mad rims :woot: .
bcause looking 2 sell nd get 18'' or 19''
please help thanks
https://www.sau.com.au/forums/topic/209649-help-with-these-rimss-s/
they look like URAS NS-01 or Koya Driftek.
What is the offset + width of the rims?
The URAS had limited sizes available, whereas the koya's had more options of different width/offsets.
Koya have recently released a 18inch design
www.autoshop.com.au
they are a decent rim, at least they arn't 20"chromies or you'd have everyone telling you off around here...
I like em... they probably arn't the lightest you can find and they may not give all girls wet panties but they're cool by me....
How wide are they, 245 on the rear of skyline ain't that big... I have 235 on the front 255 on the rear others have up to 275 but tyre width aint everything and you can go too wide, there is also a slight cost factor in tyres as well...
reckon there ns01s.
the drift teks spokes dont "wrap" back inwards that much...
if you pulled one off, should (if there NS-01s) have a sticker on the back displaying widths, offsets etc...
i reckon it looks good with em on man, just needs to go an inch lower :D
BEE_R*, URAS NS-01's and Koya Drifteks all look similar.
If they's NS-01's or Drifteks - $$1200 a set new...
If they're BEE-R's, Which arent produced anymore, over $2200 a set.
The Verdict - URAS NS01's, in 8's and 9's, +30 offset.
Drifteks have a slightly different centre, and the BEE-R's have different spoke widths/angles.
thanks for the help boys..
ill get u back with the offset nd stuff like that..
lol i no 1 nch wud suit it but i scrape enough as it is lol
there still alright 4 17'' but i wud like 18'' version :thumbsup::)
yer im looking 4 rear pods:s havnt got them yet
yer i no fresh on my greens :thumbsup:
theres loop holes in the system u just gota find it;)
im aloud 2 drive it
with the help of my dad (skyline enthusiest)
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
