Full respect to the cops that take their job seriously i just dont think in that short amount of time you can possibly learn every part of the law.
For example it takes 3yrs + 1yr on the job training to become a tradesman in most trades.
And thats pretty much just for 1 line of work,no where near how various the challenges police officers face
every day.
6months would be how long id expect it to take just to learn ALL the traffic laws let alone dealing with domestics and all the other usual crap they have to deal with.
Not bad mouthing cops,just saying if their going to do something,do it right.
  • Replies 47
People here talk the talk but can they walk the walk... Doubt it!
Oooooooooooh
Not only can I talk the talk and walk the walk... after much practice I can now talk the talk and walk the walk simultaneously :(
*swells with pride
hehe smartass...
Fair enough they should do things right.. but everyone makes mistakes.
Under their uniforms they're flesh and bone just like everyone else.. difference is they enforce the law. Someone has to..
anyways, I think this thread is lost.
I read the event at work today.
Interesting circumstances thats for sure.
Actually, it wasnt interesting at all. Boring as bat shit. Interesting is meeting the guy that got done importing 251kgs of cocaine worth over 70 million...
Edited by [200]
even better: don't be a theiving scum-bag, steal a car, run into other cars while running from the cops, lose control, cross 4 lanes and a median strip, and mow down half a garden and run into an extremely large sign
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
