Hi all
What do you guys recommend for 18*8 +35 and 18*9 +35 rims?
Option 1
235/40/18
265/35/18
Option 2
225/40/18
255/35/18
Option 3
225/45/18
255/40/18
They're both as close as you can get in terms of rolling diameter
1) Is there much difference in pricing between the wider set or narrower set?
2) Option 1 would probably be a little more comfy as there is more side wall, but maybe too sloppy?
3) car is lowered 340mm wheel to guard so would like to avoid scraping and rolling, but have the wheels sit as far out as possible.
Im running 235 on a 8" wide rim now and it seems fine to me. Is 265/35 okay for a 9" rim for the rear, would love the fat look but not wanting to drive on rubber that feels too wide and sloppy. Might get away with it with decent tyres.
Will probably be running Falken FK451 on the rims as I am pretty satisfied with the older FK451's. Plus, they're much cheaper than the Bridge. RE001, Dunlop Sport Maxx, Eagle F1 variety and probably not too far off, yet much better from what Ive read than the crappy Nankangs and even Kumho Ecsta SPT's.
Best quote so far for FK451 is $215 for the 235/40 and $270 for the 265/35, each.
Thanks!
https://www.sau.com.au/forums/topic/209678-recommended-tyre-size/
Hi all
What do you guys recommend for 18*8 and 18*9 rims?
Option 1
235/40/18
265/35/18
Option 2
225/40/18
255/35/18
Thanks!
Hi , im actually getting the same as your option 1 this coming week. i have pre tested the sizes with federal tyres and will be fine.
im getting the federal tyres for 235x40 18"s fronts for $181 each and the rears 265x35 18"s for $256 each through Access Auto on the forums here and they do ship interstate.
cheers
David
I've run Option 1 with numerous sets of 18x8 and 18x9 and also 18x8.5 and 18x9.5...not a lot of difference to be honest look wise or performance wise, and definately the way to go. 225s on the front look a bit too narrow.
And +1 for the FK452s as well...awesome tyre for the price..I'm on to my 2nd set now...
  • 3 weeks later...
Option 3 added: like the idea of a slightly higher profile, more comfort and also a fatter look.
Anyone used 225/45 and 255/40 tyres?
The above profiles are only suited for 17s...if you use it on 18s it will increase your overall diameter and throw your speedo out. In QLD, it would be illegal due to it being more than 15mm above the factory rolling diameter.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
