Hi All,
I am getting a brake master cylinder made for me at a local engineering shop called Seldom Seen Engineering.
IT bolts off the strut tower, and has an adjustable bolt to ensure the bit fit with the cylinder. It is being made of 3mm mild steel with gussets... Very strong....
If we can get an order of ten together he will charge $50 per stopper. I think $10 will cover the postage, but I'll double check for each individual so that no ones pays more then what they should.
End: End of March.
Thanks,
Thomas
https://www.sau.com.au/forums/topic/209697-r33-brake-master-cylinder-stopper/
What is the finish? Painted or bare or polished?
Pics of design or a sample?
Interested
would like to knoe too please very interested
Cheers
Allan.M
cheers guys... I am getting mine made as a test early next week...
Design is quite simple yet strong. Coming from the strut tower (which it will bolt to using the existing threaded holes) it will be a L shaped bracket with a gusset along the bottom.
I will be painting mine matt black so it blends in with the engine bay and doesn't cause the blue brigade to show any interest.
Would you be able to get some for R32?
Dont have an r32 so I can't figure out the dimensions. Mine will be made in the next week and I will post the pics up... Should be sweet!
so how did it go got any pics yet dude.?
  • 1 month later...
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
