R33 Brake Master Cylinder Stopper
nuclear_skyline
 Share
Hi All,
I am getting a brake master cylinder made for me at a local engineering shop called Seldom Seen Engineering.
IT bolts off the strut tower, and has an adjustable bolt to ensure the bit fit with the cylinder. It is being made of 3mm mild steel with gussets... Very strong....
If we can get an order of ten together he will charge $50 per stopper. I think $10 will cover the postage, but I'll double check for each individual so that no ones pays more then what they should.
End: End of March.
Thanks,
Thomas
cheers guys... I am getting mine made as a test early next week...
Design is quite simple yet strong. Coming from the strut tower (which it will bolt to using the existing threaded holes) it will be a L shaped bracket with a gusset along the bottom.
I will be painting mine matt black so it blends in with the engine bay and doesn't cause the blue brigade to show any interest.
so how did it go got any pics yet dude.?
  • 1 month later...
 Share
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
