Nissan Skyline R33 GTST
Year: 1993
Website: Carsales, Skylines Australia, Boost Cruising
Item Condition: Neck breaking head turner
Reason for Selling: New car
Price and Payment Conditions: $15000 ono $13900
Contact Details: 0405987261
This 1993 R33 GTST Skyline has been with me for 4 years, Previously with an RB3026 conversion it has since had a standard 80,000km engine and transmission conversion from a half cut.
The car is now basically standard with the whole rear K Frame end having been replaced including diff, arms, shafts, hubs and everything else associated.
The reason for this was that the whole drive line package previously in the car was sold together.
The clutch has been changed to a heavy duty sports organic and flywheel machined and a complete oil and cleaning service done on diff, engine and gearbox.
A 3" straight through exhaust with highflow cat has been fitted from the down pipe to cannon muffler.
Front mount intercooler kit and pod filter have also been fitted.
The car has been completed cosmetically with a full Nismo 400R style body kit including vented bonnet and genuine Nismo 400R plastic side skirts.
Bilstein shocks with king low springs.
A 42mm alloy radiator has also been fitted aswell as new Nismo master clutch cylinder and new slave with braided line, radiator hoses and heater core hoses aswell as new battery.
In the lighting department there is also a set of new 10000k H.I.D's.
The car has 18" 9.5" F-R Super Advan wheels with 90% tires which fill the guards the way they should and look amazing.
The car has also just been cut and polished.
Some pictures below :)
Will put up some more pics shortly.
https://www.sau.com.au/forums/topic/209731-nissan-skyline-r33-gtst-gold-coast/
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
