Stagea Exhaust
chef_stagea
 Share
if your looking for an aftermarket option then you should try a well known exhaust place and they will be able to point you in the right direction mate....
ive heard s13 exhaust shoul bolt on you just have to relocate the mounts
You sure?? There seems to be alot more wheelbase on the stageas than a S13........
Maybe just buy a muffler and get it fitted up with custom pipework at Exhaust Tech or something
This has been mentioned a few times, but also make sure you get 2 mufflers to reduce cabin drone instead of 1 muff 1 hotdog or whatever.
Interested to see what you get as i'm in the same boat but don't wanna spend 1k+ for a jap one.
Edited by webng
mmmmm. where to start
ok.
Just Jap sell a bellmouth 3inch stainless steel turbo-to-cat pipe for $220 delivered roughly. get that.
get a high flow cat converter
for the rear, I believe a R33 4door cat-back system will fit BUT it will need around 30cm welded on in length.
you do NOT need 2 mufflers.
A nice 3" straight through muffler (i use a Kakimoto gtr-racing muffler) is fine, best just to get an exhaust shop to fit the front section, measure the back section and then custom bend the pipe section from cat converter to muffler, welding the muffler on for you.
easy.
i got a quote from everlast mufflers for a complete system, dump pipe, (bolted strait to the turbo) apparently theres some type that bolts onto the stock pipe :S. high flow cat. and the bak has 3 inch mandrell bent stainless steel with a cannon for $1600. he said he could do a 1200 one using cheaper metals and lower qaulity cat. and if i wanted i could mix and match... what do you guys think of this :S is it just me or is it fu*kn expensive?
well i have a split dump, highflow cat and 3.5" Greddy cat back system and i paid roughly the same price from memory......if your going for an aftermarket option then definatly worth spending the extra on a good quality metal pipes mate....its a good upgrade and highly recommend a good quality system...i have had it for a couple of years now and its given me no problems at all....apparently D&T and AAA exhausts are very good with prices and quality workmanship....AAA recently gave my mate a quote on using stainless steel from turbo back $1200
I've got an R33 system (twin cannons) about to be fitted to my Stag. I'll take note of any changes/problems and give you guys an accurate account of how it fits.
BTW I'll be throwing on a muffler between the cat and cannons to quieten her down. :D
Don't forget, there are different grades of stainless steel.
Some SS systems can still rust easily.
:D
Demand and supply.
Lots of people want exhaust work and are willing to pay what the shops ask.
go to exhuast technologies and speak to marky, he is good with prices and everyone knows his shop and product, highly rated and great quality, or D&T at salisbury and speak to gav, he is the person to talk to bout import exhuast systems.
 Share
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
    • Talked to another R34 GT-T owner, he said bonnet of his car once fell and slammed from full height because of strong wind at a car show and nothing was damaged or broken, so I guess I'm just overthinking some things but yeah, just making sure I'm not damaging the car anyhow cause wanna keep it for a long time.
    • I would say 100% that it doesn't matter at all. I have an Al bonnet and I drop it sometimes, push it others. Have done so for 25 years and there's no way to tell that either has caused any problems (because there are no problems).
    • yeah, a black 4 door HR, stock AT RB20DE. Was a pretty good daily summer car, it was kept in a garage during winter but previous owner was fighting rust so most of the car was covered with rust undercoating, the trunk, floorpan, it started to rust underneath so I thought it would be better to find other chassis that was taken care better and do rust preventions myself, at least I would know where keep my attention at. Plans are simple, enjoy the car as much as I can, mostly on summer of course, winter here is long and not kind to 90s JDM, I wanna keep it mostly stock like, I'm not a huge fan of GT-R look or any body kits so gonna keep it as metal as possible haha, something more balanced look wise and yeah, work on performance, I was thinking about RB25DET but 20DET actually feels fun, as long as it's reliable I think I might keep it.
