1996 Nissan Skyline Gts25t
88,000kms
Automatic
Full Electrics
Alarm with 3 point immobiliser and shock sensor
Engine Mods
HKS 2530 Turbo
HKS Adjustable Actuator
Braided oil and water lines
HKS Split Dump Pipe
AVO 3in Turbo Back Exhaust
JMS 3in De-Cat Pipe
Spitfire Coil Packs
Greddy Exhaust Cam Gear
Trust Type RS Blow off value (Plumb Back)
Apex power intake
HKS Type S intercooler Kit (including aluminium piping)
Nismo Fuel Pump
Nismo Fuel Regulator
Apex Power FC with hand controller
Blitz SBC ID3 Boost Controller
Transmission Mods
MV Auto Stage 2 Valve Body
MV Auto Trans Cooler
Suspension Mods
Bilstein Shocks
King Springs (Lows)
Whiteline Camber Kit (Front & Rear)
Whiteline Castor Kit
Whiteline Sub Frame alignment kit
CUSCO Front Strut Brace
Standard Skyline Rear Strut Brace.
DBA Slotted Front Rotors
Bendix Ultimate Brake Pads
Bridgestone S03 tires (225/50 – 16)
Interior Mods
Apex Boost Gauge
HKS Type 1 Turbo Timer
20% Tinted Windows
Sound Mods
Sony XPLOD Head Unit
Sony XPLOD 6.5in, 3-Way Speakers (Front)
Sony XPLOD 6x9, 3-Way Speakers (Rear)
Reg:07/08
I bought the car 6 years ago, completely stock standard, and have receipts for every single mod done to it. Car was bought with 35,000kms, and I am the first owner in Australia.
Car gets serviced every 5000ks with full synthetic OWS fluids. The 100,000kms service was done at 70,000kms, just for peace of mind.
Car puts out 230rwkw.
Car has a few small scratches and dents that will be fixed up before selling.
Only selling this car as I bought a GTR a while ago, and I can’t afford to have 2 weekend cars.
Price: 15900
Contact Details: 0423 255 886
E-Mail: [email protected]
https://www.sau.com.au/forums/topic/209807-1996-nissan-skyline-gts25t-auto/
  • 1 month later...
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
