Again building our race and dyno proven monsters due to the sh1t service and quality NSW/ACT engine builders are providing. Also have engine removal and installation as part of our services...will keep you posted of opening dates.
https://www.sau.com.au/forums/topic/209809-dirtgarage-engine-shop-opening-soon/
Thats a pretty broad brush there dg, Surely not all of them are bad.
Good luck with the new venture dude.
Cool idea.I hope your prices will be competitive.
It seems the big guys can charge what they like these days,and we pay it thinking we are getting the best there is.
Not the case sometimes.
the bad ones are shocking, the good ones take too long and smash holes in your wallet. Not a new venture...just restarting an old one.
Does croydon fit under that umbrella?
I respect what you are doing.
Thats why I have just open my own workshop complete with Full CNC mill machine and 800mm bed lathe, Bi-metal band saw, hoist, Tig and mig etc etc so i can complete engineer any part to my spec which includes making a torque plate for my RB26DETT which no snapper head machine shop over in WA seems to think in important in rebuilding an engine....
Separate to croydon...they are in Sydney...im in Newcastle.
So per/hr rates or fixed priced rebuilds on a sliding scale like some people are doing with 2jz's at the moment?
fixed price mate...none of this bullsh1t mega dollar shock bill at the end of the build. But parts up front fee will apply, pretty fair i think.
Will also have pre-assembled change-over long engine packages for stock/mild engines to save vehicle down time.
Sounds fair to me. I got some fixed pricing on 2jz package’s, as copied below. What’s your pricing like in comparison for an RB26 (obviously will vary depending on brand of part ect).
Head package:
Full reco
1mm os crower ex valves
stock intake valves
performance springs valve springs
ARP head studs
ACL proseal MLS gasket set
full port, including chambers
Valve clearances set
Head fully assembled
Match ported manifolds
Ported throttle body
$4000
or labour only, supply your own parts
$2500
Options:
Kelford 268/272 9.9mm lift cams - $830
1mm os crower inlet valves - $500
3/4 engines - everything below the block face:
Basic re-ring:
Hot tank everything
Hone bores
Deck block
New NDC bearings
New hastings chrome rings
Including modified oil pump
Full gasket set
$2150
Re-ring & blueprint package:
Hot tank all parts
Line hone & fit ARP main studs
Close & hone rods & fit ARP bolts
Hone bores
Deck block
Stroke equalise, index & blueprint grind crank
Balance
Modified oil pump (better flow, sort blown front seal issue)
New NDC bearings
Full gasket set (you get everything else I don't need for the bottom end)
$3550
Built forged bottom end:
As above, but add
Scat H-beam steel rods
Arias Forged Pistons
$5050
Complete engines:
Tentative prices, not finalised yet but should be close
Fully assembled engine, re-ring & blueprint as above, ported & reco'd head as above
Modified breathers
New belt, tensioner & idler
$8000
Built forged engine, as above but Scat rods & arias pistons
$10 000
Options:
Kelford 268/272 cams - $830
Thanks,
- Josh
Yes this is very much needed, especially in Newcastle.. my crank collar was machined on by the best machine shop in Newcastle and it was done incorrectly which ended up costing me $1300 10 months down the track.
I was told to shutup and get over it, because everyone else in newcastle was WORSE then these guys.
You just cant win.
Welcome aboard!! once you get this going il send a few people your way!
Paul, will you be selling the same motor as in twoogle to customers? (same CR and cam specs)
simple answer....no
mostly going to concentrate on quick change-over street based products. We are aiming to have a least 1 built 25 and 26 forged street engine ready to instal for a 1 week pickup and delivery (we have a tilt tray towtruck) of cars. Cars delivered back running and ready to run-in, we believe we are the only ones in Australia that will be offering that kind of turnaround. The period of time cars are off the road awaiting engine build is a bit of a joke, and better service in this area is what we are aiming for.
Twoogle's engine was a $20 000k+ job which is very detailed, time consuming and the headwork was done out-of-house and took forever, not willing to put our customers through the agonising wait for such work. Will be building plenty of 400kw 10 sec engines though.
simple answer....no
Thats an awesome service!
Mines off the road now for 2+years so yeah, love the idea :whistling:
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
