nah,not on purpose :banana:
i was waiting for tightarse tuesday for discounts on the petrol!!
The intank fuel filter should be able to handle it.-Last tiime i drained a fuel tank was years ago with my 83 prelude- after almost 20 years it had only a little bit of sediment in the tank...
  • 1 month later...
anyone used shell's v-power racing 100 octane?
i'm just worried about the E5 (ethanol) content in it as not all cars are compatible, and as with imports I have not found any references whether V35 is Ethanol tolerant...
Yeah ive used it a few times from said pertrol station and with the same results, i wont use it anymore however as the car has been tuned for 98ron and im now getting around 550km's to a tank all city driving with the new ecu.
Milton which is the closes shell that stocks it...
they haven't had it for over 6 weeks now... quite frustrating
they make more money by using the ethanol with the 91RON - as more people can afford it.
What sort of new ECU did you put in?
ive been using boost98 and notice a much smoother engine and drive. have to say i was quite concerned about the 10%ethonol but did a shit load of research and could find a major thing to be worried about. i did make sure i filled up with a full tank first go though and the ethonol blends with water that may be sitting at the bottom of your tank (this does happen) from moisture.
second tank through. much more impressed. did 510km country driving with just under half tank left, 4L V8 economy.... i was impressed.... not sure weather it was the fuel of ECU reset but it fogged factory specs. done it twice now.
Edited by Redback
some members on G35driver has reported that changing or cleaning the O2 sensor helps with the economy too. and of course best to do a ECU reset with it... Havent tried it, might give it a go this weekend. However our car is known for it's fuel sucking engine... i dont think we will see a lot of improvements with ECU tunes or change fuel types, it comes down to the driving style...
We have several topics on this issue (one would suffice and probably cause less confusion). However if you read through all, you will find that these cars are actually pretty economical, as Warren has pointed out. I almost fell off my chair after reading the above comment "fuel sucking engine"...maybe next to a Toyota Echo.
Am I the only one here blown away by how good the economy is on these cars?
when i first got my car i was travelling to Wondai on a weekly basis, and the fuel economy was unbelieveable
you just don't expect to get >800kms out of a tank from a car with this much power
especialyl coming from the fuel-sucking engines from R-series skylines.. now they are horrible on fuel economy
but you'd expect decent economy from such advanced engine design that hte VQ has, not to mention the fact that its an NA
you're kidding, right??
this has to be one of the most economical for its power output cars i have driven for a long long time..
no im not kidding, if you have look a the figures on modern day 5-6L V8s with over 300kw, they consumes about 13-15L/100km. so in comparison, its no where as efficient ...
Have you owned a 5-6L V8 with over 300kw? I can tell you real world figures are far from those as mentioned.
Currently my 35 is getting closer to 12L/100km.
Hi Mate:
Any recommandation in SYD for change of O2 sensor and reset ECU in inner west area? I don not want send my car to some work shop has no idea with import car.
Thanks
Hi Mate:
Thanks
try to clean the O2 sensor with some rubbing alcohol first. as to reset ECU, u can do that urself, hmmm if u have access to the G35driver's forum, there's a dedicated thread on that...
Thanks a lot.
Let start searching.
Got it:
I've done 2 things. 1/ Checked the ESM (section EC-68) for confirmation of this procedure, and 2/ done the procedure on my G.
I tried several times to do this without success b4 succeeding on about the 4th try.
-------------turned ign. to on & waited (only) 3 seconds- just 'on', not started!
--------------floored and released gas/p 5 times within 5 secs.
--------------waited 7 secs then floored gas/p for 10 secs at which time the check engine light blinks
------------- release gas/p
------------- floor and hold gas/p for 10 secs.
-------------your done.
seems timing is very important on this
I've done the procedure but have no idea if it's had the desired effect yet. Won't know that 'till later today.
If successful, this looks like any easy way to erase the ECU's memory. I'll post my impressions later. Would someone else try it too?
Thanks a lot.
Got it:
One thing to note guys. We have a different ECU to the US G35.
I have looked into having mine reflashed and in speaking with a workshop in the US have confirmed that they are different. (This place has both)
Not sure if doing the steps would be doing anything bad, just saying.
If anyone gives it a shot, let us know.
Cheers
Bobby
I went with an autronic, apparently the first in the country with one fitted as autronic and my tuner both helped eachother to write the software to run the car... more headaches but at least it goes now, and a hell of alot better and more economically then it did before.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
