Sorry if it's a repeat topic, I did some searching and didn't come up with anything (forum search software blows).
Now, I'm about to get a FMIC on my R33 S2 and I wanted to know, where is it ok to put my front number plate?
I've seen a couple of cars with it off to the left hand side which is good for me because I'm wanting to do a simple air-intake where the side mount used to be. But what are the legalities involved with relocating the number plate?
Eventually I'll get a slimline plate for the front to make things easier (plus I prefer it to be the the center -- looks more balanced), but until then where can it go?
https://www.sau.com.au/forums/topic/209827-front-number-plate-placement/
looking at the car headon i've got mine on the bottom right haven't had problems with p olice or n ething they pulled me over b4 but never said ne hting about the number plate bein there =)
seen a few people with it on the left
Get some custom plates and get a slim line plate for the front :action-smiley-069:
Yeah, I think I might have to do that sooner than I thought. Maybe I'll just mount the number plate a little higher until I have more money to blow on plates. :)
The hard thing is, space is pretty limiting. The fog lights may be a bit too much in the way to put it off to the left.
Get something like a couple of L brackets & join it to the bumper in the gap underneath the lights.
Yeah, I think I might have to do that sooner than I thought. Maybe I'll just mount the number plate a little higher until I have more money to blow on plates. :action-smiley-069:
Yea, thats what I've done. I just made a bracket that lifted the whole plate up by about 60 to 70mm.
Mine is mounted on the drivers side on my BNR32 Righthand side. Cops have pulled me over and said nothing. And unfortunately the multinovas still get ya. Comes up clear as day in the infringement photos. :banana: and i'm sure thats all the police care about.
Edited by Public Enemy
I have a Cusco number plate offset kit that uses the original holes and moves it off to the passenger side. I never used it. Stainless steel bracket, still in the packet. (That rhymes!)
Let me know if you are interested. By the way, all Alfa Romeos have it on passenger side from factory. The only legal requirement that I am aware of is that it has to be mounted so that it is parallel with the axle - so you cannot have too much of an angle.
Cheers. :banana:
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
    • Hi Luke, haven't thought about it a lot, trying to get the car into the paint shop first.  Did you want to make an offer? As stated above, I'm just looking for fair market price.
