I have some bits left over from my 31, gotta sell
Microtech LT-8 with loom to suit RB25DET - $900 NOW $800
4 stud 17 inch Rims with right offset for r31 (without tread) $600 NOW $500
3 inch cat back exhaust with twin cannons, (suit r31) $400NOW $350
Hybrid copy FMIC $170NOW $150
Located on the sunshine coast in qld
Edited by AHH31
whats the offset on the rims, how close are they to the guards are they?
dunno what the offset is, but they were the only ones that were the right offset to suit r31 that i could find, they are prob 10-20mm from guards from memory, hard to tell when i dont have them on a car anymore.. ur welcome to try em on if your interested
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
