Hi guys,
I recently bought an R34 GTT tiptronic coupe, my first Skyline but I have owned many turbo cars over the years.
Current mods are limited to a HKS catback exhaust (came with the car) and since reading your illustrious forum I have done the free dual stage boost disable mod and ordered an R32 wastegate actuator (havn't had time to fit yet) but have been told this will give me a solid 10psi.
Basically I commute a lot in traffic which is why I chose the auto, I'm usually a manual man. I find the tiptronic pretty good and not too boring but it does have that auto syndrome where it takes a while to get moving on light throttle applications. So I'm really chasing low down/mid range urge combined with decent fuel economy. I must say I was dissapointed with the first tank - 320km then the fuel light came on (my 03 WRX used to give over 400km every time with spirited driving).
From research I have done on here my options for further mild performance mods could include:
- front/dump pipe $199 approx.
- High flow cat - $180 approx.
- Apexi SAFC NEO - $295 + install and tuning
(above are the best online prices I have found)
Now I'm thinking for under $1000 the above would give me a nice little gain - BUT I dont want to ignore cosmetic mods either. Unfortunatly car did not come with a rear wing so I am desperatly trying to source one (PM me if you have one) and also thinking some nice lowered Tein springs and some 18" black rims would finish the look off nicley (car is white).
Of course all of this adds up so what in your esteemed opinions should I be looking at first? I am keen to get the fuel consumption under control which I have been told an SAFC should be good help - but is there any point in installing one without doing the dump/cat first? ect ect. Because if I do the dump/cat later surely it would then require a costly retune??
Any comments appreciated!
Edited by colossus
- Split/dump pipe $199 approx.
Got links to those prices? $199 for a split dump and $295 for a AFC NEO seem a little too cheap.
Anyhow, i'd definately be doing the split/dump and the high-flow cat... then having your afc fitted and tuned. See how you go, before spending money on a turbo upgrade, computer management, etc.
Do the mods, you will get gains. The full exhaust will give you meatier acceleration.
Fuel consumption= service the car if you haven't. I mean fresh synthetic oil+filter, NGK plugs, clean the AFM, throttle body cleaner, flush the intercooler with degreaser, clean oxygen sensor, injector cleaner and only use top fuel (IMO V-Power or Ultimate).
Since i did all this my Skyline pulls 500km per tank (manual).
Woops edited original didn't mean split but it is a dump/front pipe in one. Still good prices - they are from Just Jap.
Thanks I'll give this a go - its got about 99,000kms so getting due for the 100,000km service anyway - which is going to cost a bomb just in parts ($100 for sparkplugs is ridiculous) - I'll do it all myself of course. Can you clean an O2 sensor? not having much luck finding a new one under $200 to fit an R34 (not sure if the EL one fits R34).
Just get copper plugs. $25 a set and change them every 10-15,000kms or so. If Iridiums get fouled they're not much use.
Yeah most of the servicing is easy. The O2 sensor can be carbie cleaned to wash off the carbon buildup. That should do the trick.
Hope the mods get the power you want mate. Good luck.
yep, iridi/palti, whatever... $100 for plugs are a waste.
They VERY rarely last that long in a modified car.
Factory, yes no problem... but soon as you up the boost, exhaust, tune - coppers are the way to go and regular servicing
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
