Whatever price you want is fair, but you will probably have a hard time selling it at the moment as there are quite alot of r33's going around for under 20k that are lightly modded.. eg body kit, wheels and a few other bits.
anyway - just thought id let u know :O
https://www.sau.com.au/forums/topic/2099-33-gts-t-manual/#findComment-40232
is it modded at all or completely stock? i gather by your lack of detail it is completely stock and in which case you might be asking for too much. then again i haven't seen the car to judge on it's condition. it has low k's and if it's in very good nick (as in, close to factory with minimal wear) then you might just find yourself a buyer who's after a quality stock GTS-T.
your price is negotiable though (like everything else) so when a buyer sees $20,900 they automatically think $19,000 or there-abouts so i wouldn't lower the price too much as you will loose some negotiating power.
anyhoo, good luck:)
https://www.sau.com.au/forums/topic/2099-33-gts-t-manual/#findComment-40630
if your wanting to downgrade i have a 180sx sr20det manual that i would trade in. Its in mint condtion with a few mods. see nissansilvia.com in the car classifieds. Canberra car too. email me [email protected] if your interested by any chance.
https://www.sau.com.au/forums/topic/2099-33-gts-t-manual/#findComment-41965
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
