Wacky Dee Posted June 27, 2009 Share Posted June 27, 2009 I'm probably missing something ... but what's wrong with just pushing the top-left button on the unit itself? That switches between high and low.. Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-4682204 Share on other sites More sharing options...
broken22 Posted June 29, 2009 Share Posted June 29, 2009 Good work figuring that out. Might have just found myself a project for the weekend. Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-4685924 Share on other sites More sharing options...
profaine Posted July 13, 2009 Share Posted July 13, 2009 Good tutorial, just wondering would it be possible to use a missile switch, i.e. one that is either on or off (or in this case one would be hi and one low?). The reason i ask is; A) I already have a redundant missile switch in the dash courtesy of the old owner and B) Then you would know whether your in high/low just by looking (rather then boosting to find out!) because I am going to mount the controller in the glove box. If anyone knows how to do this if it is possible I would appreciate if they posted up instructions as I am not electronically savy enough to figure it out myself! Cheers Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-4711966 Share on other sites More sharing options...
fastR Posted July 14, 2009 Share Posted July 14, 2009 Thanks for that it helped a lot. Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-4713810 Share on other sites More sharing options...
HitmanSF Posted October 26, 2009 Share Posted October 26, 2009 I stumbled upon your video on youtube, and I made my own too! I would have never thought of making my own, Thanks. http://www.youtube.com/watch?v=4uVYUHlZeyQ Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-4902037 Share on other sites More sharing options...
JoelyMoley Posted April 7, 2010 Share Posted April 7, 2010 what do people think about it working with a switch like this? http://www.jaycar.com.au/productView.asp?I...mp;SUBCATID=448 cheers guys Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5169563 Share on other sites More sharing options...
Duncan Posted April 7, 2010 Share Posted April 7, 2010 that won't work (on-off) but this similar one will (momentary on) http://www.jaycar.com.au/productView.asp?I...mp;SUBCATID=448 Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5169595 Share on other sites More sharing options...
JoelyMoley Posted April 7, 2010 Share Posted April 7, 2010 that won't work (on-off) but this similar one will (momentary on)http://www.jaycar.com.au/productView.asp?I...mp;SUBCATID=448 thanks heaps for that duncan, should look nuts with a missile cover on it Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5169603 Share on other sites More sharing options...
JoelyMoley Posted April 9, 2010 Share Posted April 9, 2010 i must be mentally retarded, unfortunately the multimeter has no battery so i tried free handing it, long story short no cake, nothing happens when i flick the switch (with wires on either side) Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5172780 Share on other sites More sharing options...
Duncan Posted April 10, 2010 Share Posted April 10, 2010 yeah bit hard to guess without a multimeter....get a battery or borrow one. where are you? Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5174074 Share on other sites More sharing options...
JoelyMoley Posted April 10, 2010 Share Posted April 10, 2010 yeah bit hard to guess without a multimeter....get a battery or borrow one. where are you? yea ill buy one when i head out tomorrow, its one of those retarded mini- batteries.. lol probably be better off just buying a new multimeter ill post my results tomorrow hopefully i don't burn the car down by then Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5174126 Share on other sites More sharing options...
Duncan Posted April 11, 2010 Share Posted April 11, 2010 yeah be careful I rekon you could manage to damage the profec b if you short the wrong wires... Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5175275 Share on other sites More sharing options...
JoelyMoley Posted April 15, 2010 Share Posted April 15, 2010 ok now im confused, i used a AUX cable i had around here but it only has 2 cables (white / red) am i missing something here? Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5181916 Share on other sites More sharing options...
skins Posted April 15, 2010 Share Posted April 15, 2010 So the idea is to go 'stealth' with your hi lo switch ? Why not use that ? I did works a treat. Can't lock the passenger window switch anymore but meh. Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5182002 Share on other sites More sharing options...
Lukas 33 Posted April 22, 2010 Share Posted April 22, 2010 Hey I know this is an old thread but I thought I would bump it up. I am putting in a 12V basic ON OFF switch for my ECU so when the ECU gets 12V it is in high boost mode and when it doesn't see the 12V it is in low boost. I am using my profec B spec II as a boost gauge only and would like it to switch between high and low along with the ECU so the warning levels for high and low change. I know people have said you cant use an ON OFF switch to do this but I think this little circuit should work. I will go and grab a capacitor some time today in between pretending to study math and see how it goes. Relay is just your basic 12V 4 prong relay from jaycar for $4. Not 100% sure on the size of the capacitor yet. Sorry if you don't understand my drawing Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5195707 Share on other sites More sharing options...
Lukas 33 Posted April 23, 2010 Share Posted April 23, 2010 ok now im confused, i used a AUX cable i had around here but it only has 2 cables (white / red) am i missing something here? I know its an old post but I figured someone should answer it. There should be wire which is just bare that will go around the outside of the white and red wire. This acts as shielding. I think the red one should be your 5V and the shielding should be the ground Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5197116 Share on other sites More sharing options...
JoelyMoley Posted April 24, 2010 Share Posted April 24, 2010 cheers mate yea ended up figuring it out! thanks again Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5197871 Share on other sites More sharing options...
Lukas 33 Posted April 25, 2010 Share Posted April 25, 2010 (edited) Ok little bit of an update on my little circuit I drew up. I have modified the circuit so that I run a small resister in parallel with the capacitor or else it will not drain the power from the capacitor and the coil in the relay will only switch once until you wait for a long time for the power in the capacitor to drain. So I soldered a small resistor in there as the picture below shows (1st Pic). This circuit has a little issue at the moment though. It will momentarily earth the 5V but it will only do it when I turn the switch on, it wont do it when I turn the switch off. I think I can get around this by putting in a little single pole double throw relay. So when I am not sending 12V+ to the ECU the +ve side of the CAP is connected to ground and when I send the 12V+ to the ECU the relay sends the +ve side of the CAP the 12V+ (therefore charging the cap). This next circuit is also attached (2nd Pic). This is different to the other circuit because when the 12V+ isnt going to the ECU the +ve side of the capacitor is then earthed. So when I turn the power off, the capacitor is earthed and the discharge of energy should momentarily earth the 5V from the EBC again. In summary it SHOULD trigger to hi boost when I send a constant 12V and then when I turn it off it should trigger low boost mode. In theory anyway. Will find out when I go pick up a SPDT relay. EDIT: I am using a 16V 330uF capacitor Edited April 25, 2010 by Lukas 33 Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5199547 Share on other sites More sharing options...
Duncan Posted April 26, 2010 Share Posted April 26, 2010 yikes. that is a lot harder than a momentary switch! I'm sure you know what you are doing.....but won't this all work backwards if someone presses the button on the controller as well? At least until you press it again. Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5200654 Share on other sites More sharing options...
Lukas 33 Posted April 26, 2010 Share Posted April 26, 2010 yikes. that is a lot harder than a momentary switch!I'm sure you know what you are doing.....but won't this all work backwards if someone presses the button on the controller as well? At least until you press it again. hahaha yeh it is a little bit more complex :S I was (and still am not) sure if the vipec ECU will accept a momentarily digital input to trigger high and low boost maps or whether it had to be constant 12V+. So I just thought I would fiddle around with that over the weekend until I could contact ray or someone. Thought I would just share what I came up with. Just in case someone is as bored/retarded as I am Guess this sort of circuit could be used in some other application in the car maybe. Yeh it will all be back to front if someone sneakily pushes the button on the boost controller :| Also a small update: I removed the resister from the "final" circuit as the resister was being a thieving bitch and stealing all of the power from the cap that was meant to go through the relay coil. So only use the resister if you only want the momentary switch to happen when constant 12V is supplied (Like the second circuit image I put up). After I have contacted one of the vipec guys tomorrow and found out if the ecu will do momentary switching or not I will decide whether or not I will experiment with different size capacitors. NOTE: the 300uF works fine for the second circuit. I only want to try different capacitors for the final circuit. Dont suppose you happen to know if the vipec takes momentary inputs by any chance? Link to comment https://www.sau.com.au/forums/topic/209903-hi-low-switch-for-profec-b-spec-ii/page/2/#findComment-5200891 Share on other sites More sharing options...
