  • Replies 441
I'll meet you at thornleigh later on if you go there :)
ummm ok but i think its gonna pass your bed time ;)
Ok so are mine looking at the car or the chicks :D
I am totally bringing the camera.. coz photography is my thing :( I make cars look more sexeh :(
Well are you a babe? with huge boobs? :D
Open space James, bring ya rain jackets :thumbsup:
Hey Sheng, just a quick question, is that carpark hard to get into cause my car is abit low and i dont want to scrap my new front bar.
Also what about Castle Towers carpark coles level if it starts raing?
Its pretty empty by 7-8pm and would have to be at least 80 -100 spots
Anyways let me know
thanks
Edited by GTR32X
Anyways let me know
thanks
I just found a new place :D coz i can :), and no you wouldn't scrap, unless you car is 5mm off the ground lol
Yeah we can consider it for next time.. ill see how it goes friday :)
woooooooot.... yessum... :P
p.s Sheng can you edit my attendence from 300ZR :( .... to 33 gtst.... the 200ZR is staying at home ;)
Yessum :)
yo wassarp ppl
am only going to the meet, am not cruising lol
got overtime doing IT shit at work the next day (sat)
so cbf staying late lol. Anyways see u all there.
3rd last days before my liner say bye bye to me lol
Edited by GTL05T
I have Galston Gorge in mind atm :rofl: nice and close ( well closeish)
Then hit Maccas Thornleigh after..
I'm keen on this you POS
should head west and do Bells Line of Road :banana:
OK, no need to get loco on us essai :D
But if everyone's in...i won't kick and scream :D
woooooooot.... yessum... :D
p.s Sheng can you edit my attendence from 300ZR :blush: .... to 33 gtst.... the 200ZR is staying at home :blush:
While your changing stuff. I'm not going in my R33 anymore :w00t:
Its Gen 1 Liberty power for me! Super ugly spec :banana:
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
