I'm out but my parting comment is that it would be madness to go grafting an R31 rear cross member and A arms into an R30 . The whole R31 platform is very different to an R30 and to think otherwise suggests that Nissan didn't know what they were doing in that era .
Dimensionally R200 long nose diffs are the same with the only meaningful differences being the rear uni joints companion flange and the inner rear drive shaft joints interface .
I am 90% sure the late short nose R200's carrier is dimensionally the same as early ones with the same offsets to suit the same ring/pinion ratios .
Some early era R200's used smaller crown wheel bolts than the later ones but solving that issue if you have dissimilar holes/bolts either way is easy .
An R200 is a mechano set diff , its a long or a short and I'll leave it at that .
A .
PS , sorry there were a few odd ball R200 viscous LSD's and those are best avoided .
Me too!
And opinions vary.
Sorry! but other than engine swaps, I will never understand why anyone wants to take something that was very well engineered by it's manufacturer and make overly dramatic changes to damned near everything. I have seen on these pages talk of using R33 brake master cylinders and brake boosters, WHY? How are the R33 master cylinders and booster better than what you have already??
Dr30 Skylines and it's predecessors were raced & rallied very successfully with steering boxes and there own IRS system for years. It's not that they didn't have the technology, as zed cars had rack & pinion steering long before the R30 came to be. If it's the feedback from the road you source so much and the old worn steering box doesn't do it anymore, get the new parts made to order so it does, it would have to be less expensive than an entire refit/conversion.
Other than wheel selection, what is the benefit of 5 stud wheels, and in any case the Japanese 2ndhand wheel market is expansive to say the least.
If it's a drum brake hand brake and other such things you want, why not just go buy an HR31 complete car instead of having a bitser, like an R30 with an RB motor and R31 rear end, the mods are extensive to say the least and when you want to sell, who is going to want it any way???
To me it's like putting an 350 Chev in an XJ12 Jag, it's a great conversion if you have no intention of selling it, but if you do, it's value is very low.
Sorry MrMayhem, but you will never convince me what you have done is for the better. There are legends in the Nissan/Datsun modifying & rebuilding business in Oz like Stewart Wilkins & Arthur Jackson, and they have never gone down the conversion track you have. So! I ask myself why bother, when the legends don't?
Cheers, D
  • 4 weeks later...
I think this thread has got away fro the issue Jon wanted to discuss. The main point of the question was to do with getting the R32 4 pots on and the rotrs and drum handbake setup and would it fit, not the benefits or otherwise of it which is his business.
I've seen pics of an R32 backing plate bolted up to late DR30 style trailing arms. The backing plate appeared to bolt straight up to the mounting holes of the original backing plate. Also the 5 stud stub axles from a Z31 had been slotted in, (not that you asked about a 5 stud conversion). Therefore the stub axles from the HR31 and the backing plate and drum brakes from either HR31 or R32 etc should work.
So just use your DR30 arms and swap over the backing plate and drum brake, and if you wnat to stay 4 stud you may have to get some hub centric spacers machined up to slip over the hub to space the rotor out 10mm as the R32.HR31 rotors are 10mm thicker than the solid DR30 ones. A mate is doing this this on his trailing on an IRS Gazelle.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
