well...when you are rich, you get the most expensive one out of the list. You pay the most expensive brand of turbo and mods. "which is better in price and performance" should not be in your vocabulary. "I'll take which ever gives me the best performance" would be the only sentence you need when you are rich.
https://www.sau.com.au/forums/topic/209971-whats-better/#findComment-3712888
hi im amjad and i want to buy a skyline when im rich which one is better in Price and Performance and how much they approxmatly cost in AUS.
GT-R r34 V-spec I
or
GT-R r34 V-spec II
or
GT-R r34 V-spec II Nur
even better why wait till your rich, why not buy one of these R/C GT-R r34 V-spec II Nur :whistling:
https://www.sau.com.au/forums/topic/209971-whats-better/#findComment-3713085
GT-R r34 V-spec I
or
GT-R r34 V-spec II
or
Hey dude, these guys are just havin fun. You obviously have access to the internet. Do the research yourself. The link below will start you on your journey, maybe motivate you when you become rich. Also, when you buy a Skyline you will stop being rich very soon. It is an expensive business running one. It is however very rewarding. Good luck.
http://www.j-spec.com.au/
https://www.sau.com.au/forums/topic/209971-whats-better/#findComment-3714664
GT-R r34 V-spec I
or
GT-R r34 V-spec II
or
GT-R R34 V-Spec I
The V-spec model also had firmer suspension, lower ground clearance, a plastic front air diffuser (covering the underside of the engine) and a rear carbon fiber air diffuser, designed to keep air flowing smoothly under the car.
GT-R R34 V-Spec II
The V-Spec II has increased stiffness in the suspension (even stiffer than the original V-spec). It also comes equipped with a carbon fiber hood, which is lighter than the aluminum that all other GT-R hoods are made from. Also different on the V-Spec II is the darker color of the center console in the interior. The seats were also made with black cloth, rather than the gray cloth used on other R34 GT-R models. From this point, the standard trim level GT-R also received the new black seats.
GT-R R34 V-Spec II Nur
The Nür was named after the famous German Nürburgring racetrack, where the Skyline was developed. The Nür model featured an improved RB26DETT based on the N1 racing engine, used by Nismo in Motorsports. The V-spec II Nür is based on the regular V-spec II model, and the M-spec Nür was based on the regular M-spec model. Other than the addition of the Nür engine, the Nür models also included a different color of stitching on the interior trim, as well as a speedometer reading up to 300 km/h (186 mph).
- http://en.wikipedia.org/wiki/Skyline_gtr
https://www.sau.com.au/forums/topic/209971-whats-better/#findComment-3715762
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
