Hey guys just interested in other peoples opinion on my situation. I was ready to sell my car but a month or so ago my r33 ser 1 caught fire as the rocker cover was leaking on the exhaust and it was heatwrapped so it just got soaked with oil heated up and sorta combusted. Now all thats been damaged is the coilpacks/power steering resovoir/ tiny bit of wiring and just general breathers and vaccum lines on the right side of the engine where the exh manifold is. The car has been listed as a repairable write off (dont ask me why) and have been payed out on my insurance claim and they have GIVEN me the car back! The way I see it, its gonna cost me under 1k to fix and have back on the road ready to sell anyway.
Is it worth fixing up and selling? If so How much are they worth nowdays with the following mods?
Or what do you think its worth in current state from what ive described?
Modifications
Full exhaust with Nismo Tip and Screamer Pipe
Hi flowed Turbo by sliding performance
2 Way locked diff
Front mount
Bored throttle body
Apexi Pod (Brand new)
New 1.2mm Cometic head gasket and machined/tested head
16inch Advan racing 3 spoke rims
Drift steering wheel
Sunroof
Type M/Mspec whatever it is standard bodykit
An over all tidy car, black in colour
Thanks guys will be good to hear back from you.
Edited by Jamie88
https://www.sau.com.au/forums/topic/209991-r33-caught-fire/
geez you came out of that alright! just fix it up and sell it cheap and with your insurance money as well you'll be set.
What does everyone think is a fair price nowdays. 13k? I know a year or so ago they were selling for 15+ with similar mods.
https://www.sau.com.au/forums/topic/209991-r33-caught-fire/#findComment-3716853
If its a statutory write off and you got paid out wouldn't that mean that its not registrable anymore?
Its a "repairable write off" so once its fixed and passes the inspection its fine to be registered again. And it was insured fire and theft for $10k I payed more when I bought it but thats all thrid party would insure for.
https://www.sau.com.au/forums/topic/209991-r33-caught-fire/#findComment-3723054
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
