Hi All.
I've recently been going through the process of researching tyre dimensions to try and keep my wheel radius consistant while i get new wheels. I'm going from 16x7" rims to 18x8.5"
I thought I'd post up a little explaination of how it all works for anyone else wondering.
Take my old tyre dimensions for example -
215x50x16 where:
215 is the tyre width (looking from the front or back of the car) and is measured in millimetres,
50 is the aspect ratio of the tyre as a percentage.. ie, the height of the tyre wall is 50% of the width in this case
and 16 is the size rim it fits, measured in inches (the hole of the tyre)
.. would have been so much easier if they just did it all in inches or millimetres.....
so in order to keep the overall wheel radius the same, the following is the equation to follow:
rim radius (half the rim size) + Width * Aspect ratio
ie in my situation:
currently : 8 inches (203 millimetres) + 215*0.50 = 310.5mm
I knew i wanted 235s, so all that was left was to find the correct aspect ratio
with 18" : 9 inches (229mm) + 235*0.40 = 327mm
: 9 inches (229mm) + 235*0.35 = 311mm
Thus the tyre size i'm installing is 235x35x18
- Steve
ps. You may ask "why is this important?" ... well keeping the wheel size correct keeps your speedo accurate as well as your odometer. Also accelleration is noticably different with different wheel sizes (especially in less powerfull cars)
I'm not 100% sure either, so if someone can correct me, please do
Edited by Wogan
https://www.sau.com.au/forums/topic/209993-understanding-tyre-dimensions/
Hi All.
Well researched, youre mostly right but the sums that you have done will not help you when you are changing brands of tyres as no one size is the same from brand to brand.
I work for Federal Tyres and it is my job to advise people of the right fitment for their vehicle.
Tyre sizes and overall diameters are only relevant within each brand and even then they are not an exact science.
For example - A 235 / 45 R17 in one brand might measure 643mm whereas in a competing brand the measurement may be between 645 - 650mm.
There are to many variables between manufacturers to be able to guarantee that you are getting the same overall diameter as your last set.
You might have to have a look at your maths again though because a 235 / 40 R18 is a lot bigger than 327mm - your looking at about 645mm for that size.
very good point bullet 32.
I am amazaed at the range of actual widths and diameters in tyres that are rated at the same size. eg a falken ze326 in 265/35/18 is at least 2 cm narrower than a dunlop dz02j in 265/35/18.
Only really makes a difference in a 4wd skyline I guess, but don't mix and match brands even in the same size
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
