Hey guys so I have this weird and ever so interesting thing that happens in my r33..
Now this only happens in one road and has never occurred any where else in all the driving of my r33 (that's what makes it weird) and I've driven the car everyday for a year now.
Okay so anytime I come to stop at the end of this road, my cars charge and engine lights come on and the car nearly stalls (this occurs as I'm braking) The road is basically flat maybe on a slight incline and the problem will only occur if im turning out of the street not into it..
I've never experienced anything like it in the car before..
Any suggestions.. I'm thinking ALIENS!!!
Definately aliens.
Thats wierd mate.
I have had a similar problem once or twice, where the lights have come on, engine revs have dropped a lot and its nearly stalled. Seems to occur randomly while braking after some spirited driving. Not very often though, maybe 3 times in a year. And nothing I can pinpoint on, definately not the same road/place.
definately not spirited driving :whistling: its a lil suburban road that my ex lives down unfortunately for me my mate still lives off the same road so I still have to use it lol.. thats why I was hoping to try find a solution or find out if you guys had ever heard of anything similar
haha!
defintion of spirited driving: driving in such a manner as to create sufficient noise and disturbance as to wake the dead.
i dont suppose this intersection has a cemetery on the corner?
haha!
Haha.
The main reason I listed that is it happened at a time after driving through the black spur. While it wasn't full throttle driving, it wasn't driving to the shops to pick up some milk.
do u feel like waking up after all that and u get that feeling of something shoved up your a$$? lol
I believe aliens can freeze ya and then they do sexual experiments on ya!
I wouldn't drive on that road again...
LMAO. That must be it.
Is there any of those high powered power lines near by?
I once pulled into a mates driveway just as he and his dad flicked the switch on an electro-magnet. Car just died. Did it a few times. Crazy stuff to watch.
    • Ah. OK. I take it back. I hadn't looked closely at the R33/4 arms and presumed that GKTech did as GKTech do everywhere else, which is to use sphericals there. The poly bushings are made to be 100% interchangeable, should use the standard bolt just fine. Every other bush in every other place in pretty much every other car, does.
    • @silviaz Ok cool, so much easier with a video. I can see why this video would be confusing for new players.   It is obvious that this entire bonnet is going to be resprayed, have a look in the background around 2:05, you can see a bunch of bare metal on the left side of the bonnet.  It's not an issue for the primer being laid down on the non-prepped clear on the bonnet. It will be sanded off at a later stage.  This might not be obvious to new players, but working on bare metal and factory paint in this instance, the factory paint is like a mountain and the bare metal is a huge valley. The bonnet needs to be levelled flat before it receives it's final stage of colour and clear coat. During this levelling process, the primer that is landing on the clear that you are worried about will be removed.  Also, this guy is out of control. Zero PPE while spraying, maybe he is a good example overall about what not to do lol.
    • Ok I FINALLY found a video lol. This took way longer than it should have as I could have sworn I saw multiple videos like this. I kept finding the completely opposite (the correct way of doing this). I wouldn't be surprised if I f**ked this up somehow.  I just realised where I've been getting confused and even with other things I work on. I haven't been doing things the regular way instead I'm going a roundabout way of doing things, like putting epoxy primer first then filler for example instead of putting just filler then primer on top of that, then wondering what happens if I get that primer on the clear coat that I haven't sanded yet. This was a bit of an epiphany 馃槀  But anyways, here this video. Time stamp, 2:56, some of the primer lands on the paint unscuffed above. You can see from the reflection it looks shiny.
    • It does, this part circled in red. I assume the OEM bolt might not work well with the poly bushing because the dimensions may be different?
    • The J arm doesn't have bushes either. Assuming that by "J arm" you mean the part of the upright that runs down from the upper arm's outer bushes to the top of the hub. That has a kingpin style bearing in it. If you meant the lower control arm, it has 1 bush, at its inner end. If you have PU in there, that is superior to Nismo rubber. If you meant the caster/tension rod - it has 1x bush at the front end, and again PU is superior to Nismo rubber. But as I said above, I would definitely get the GKTech arms for that, as sphericals slay all other options there.
