hey
cars been on the dyno yesterday and today. all was going well until he decided to put more boost in it. he cant seem to control the boost with the ebc. he said there is just too much air running through at the same time. the most boost he can get out of it is a quick spike to 8psi when using the actuator. he reckons that with a bleed valve it would do the same thing again due to the larger capacity of the engine. it will hold a consistant 5psi.
has any one else had this issue?
is there away to overcome this?
he has tuned it plenty rich enough for me to take it to about 15psi/280hp so i can try and get my ebc to work
could i try adapting a stiffer actuator onto it or what? i think the problem is the actuator is just too soft and no matter how much control the ebc has the actuator is still going to open
the engine is an rb25 with a hypegear tr43 turbo and a gizzmo ibc
https://www.sau.com.au/forums/topic/210043-boost-control-issues/
sounds like a lazy actuator that is staying open, if you bypass the boost controller and just run the car off the actuator is the turbo really slow to spool up?
yeh it is. but its not to bad. i didnt get a printout of the dyno sheet cause im going back next week when its sorted.
the tuner also told me that i may need to put restrictors in my vac lines to the solenoid and after the solenoid as theres too much pressure for the ebc to deal with. he said it may fix it but wouldnt be ideal.
Edited by adam87
Is the cat ok?
there is a distinct lack of cat;)
i have a 3" decat pipe. the exhaust is a 3" straight through to 4" pipe as the tip
i took the hose off the actuator and ran it like that to see if it built boost with no source for the actuator to operate and it did fine. iv moved my ebc solenoid much closer to the turbo now and will try it later today and then if it doesnt work ill try put some restrictors in the ebc lines and also try a bleed valve
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
