well my goal was always 700hp at the wheels on pump gas. probably a bit of a stretch with the T04z. Might do it with the 1.00A/R exhaust housing.
But i'd be pretty happy with anything over 600.
Going on other setup somewhere in the low 600rwhp is probably achievable but with the stroker and large a/r turbine housing you'll probably do it on less boost than what others have used. I've seen a vq30det with a t04z on meth on an engine dyno max out with 750hp with boost starting to taper off late in the rev range which pretty much indicates the turbo was maxed out.
  • Replies 58
Looks the goods m8 welldone. My setup pretty close 2 yours just dont have the stroker crank & cams a little different ive got 280 tomei in mine plus i got lucky 2 get a N1 block. Have 2 compare dyno runs when both are finished lol. You running .81 or 1.00 housing first. :teehee:
Looks the goods m8 welldone. My setup pretty close 2 yours just dont have the stroker crank & cams a little different ive got 280 tomei in mine plus i got lucky 2 get a N1 block. Have 2 compare dyno runs when both are finished lol. You running .81 or 1.00 housing first. :whistling:
yeah mate i was following your build. was keen to see how it performed on the dyno. How is it going anyway, get that shim issue sorted yet?
Going to run the 0.81 first, most important result for me at the moment is how responsive it will be.
cheers
Paul
There are a couple of RB26's getting around oz making 650 at the wheels with the T04Z. I figure a bit more torque from the extra capacity and a few more revs should see it get close to 700.
Not sure if i want to hit it that hard thou.
Be more than happy just to be banned from the plex for running a 10. hehe
cheers
Paul
Yeah the head is off engine out something wrong with valve guides apparently they found a few shavings in head from guides so its back at the head shop valves had a couple of scuffs on them they havent told me if its exhaust or intake but most prob exhaust but keep ya posted.
bugger man, there's always something ay.
i guess it will be all worth it in the end but sometimes it seems there is no end.
Ya dead right cant win was going to have it back 2 weekends ago they run it on dyno with 14psi & it made 311kw with no timing or full tune this on run in tune. Reved it 2 6500 only so it sounds kinda promising.
Edited by blitzxtr
  • 2 months later...
Just a quick update.
Intercooler piping done, custom catch can, custom over flow and header tank.
Just wiring up the last of the electronic gadgets now. Should be starting up this week. Nervous times! lol.
Thats MAD!
How does the HKS T04Z go?
Whens the boost kick in and how much you running?
I have sat in a R33 GTR with a GReddy T88 and the thing is lagy till 6000rpm and then it flys.
Also noticed you got the one piece inlet plenum... You planning for drag races?
Edited by (00)SKYLINE(00)
Dunno how the T04Z goes yet. Last time of drove my car it have R34 GTR turbo's.
Planning to run 1.8 to 2 bar boost.
Yeah the Hypertune plenum and single throttle body is becoming a favourite for drag racers. I'm planning on doing abit but nothing serious.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
