Dunno how the T04Z goes yet. Last time of drove my car it have R34 GTR turbo's.
Planning to run 1.8 to 2 bar boost.
Yeah the Hypertune plenum and single throttle body is becoming a favourite for drag racers. I'm planning on doing abit but nothing serious.
Mad! Looks like your going for full top end performance.
:rofl: English ninja :P
Hah! I fixed the sentence now.
  • Replies 58
looks awesome mate, im running same turbo and jun 2.7L kit, engine has made 585rwhp on 18psi on a very low reading dyno (reads 40hp less than another brand new dyno dynamics shootout one i have gone on) but its currently running 560hp (18psi also) at wheels with a very rich safe tune for the moment, plenty left in it, i can see yours definately going a touch over 650rwhp with the 0.81 depending on the dyno and more with the bigger housing. I have similiar mods except the hypertune plenum, but im getting one very very soon, be good to see how much of a difference the plenum makes.
whos doing the tune work in Perth?
  • 3 weeks later...
Engine is tuned to 4000 rpm while i run in the engine. Once i get a 1000 kms up will be in for more tuning. Hopefully next week sometime, depends on work.
Making around 10 psi at 4000rpm with no cam tuning so kinda looking promising. Off boost drivablity "feels" improved over the old set up and although this turbo is a later coming on boost compared to the stock turbed RB26 (380whp) i was running, the torque curves overlayed are almost identical to 4000rpm.
The damn thing is loud and sounds pretty cranky too.
I purchased the complete HKS T04Z kit through Greenline, awesome gear, highly recommend it on looks alone.
Welldone m8. I had my car dynoed yestserday made 327kw on 14psi then made 378kw on 16psi & then on 22psi made 401kw but the old 700cc injectors are maxed out so 1000s it is. should make a lot more hopefully the torque is quite strong so using all the fuel but torque is good. Put the 1000s in & race fuel plus 32psi & look out hopefully crack 500kw. Anyways Enemy have a good1 like to compare dyno sheets when ya have them since these setups are pretty identical.
yeap so far so good.
quite surprised to see over 400 kms out of a tank of fuel with it running quite rich, 880cc injectors, big cams and no closed loop. Needs more power thou, hehe.
nice work Blitzxtr, get a dyno sheet up for us to have a look at if you don't mind. Have been keen to see how your build has gone.
Unique1, cheers mate. All the best with your's as well. I'll have my fingers crossed for your bottom end lol.
SLY33, idle is a bit high at the moment but it does sound mean. I dread ever having to pull up along side a highway patrol vehicle. Certainly wouldn't use cams bigger than 272/11 for a street driven vehicle, even these are probably a little to big.
f**k im currently in the process of putting my tomei stroker kit into a n1 block and the cams im using a 280's with 11.8lift. and yeh its street driven hahahaha this really is gonna be interesting
some more tuning has been done and the rev limit increased to 8000.
Making 544 hp with 17psi and 16 degrees of timing.
should get interesting with more boost and a play with the cam timing.
nice work, looks very similiar to mine on similiar boost :) is 8000rpm the limit of the 2.8L kit or is this just a safe limit for the moment? is this on the 1.0 ex housing? fullboost at a fraction under 5000rpm looks like it, mine is making 18psi by 4300rpm i think from memory.
Edited by unique1
Thanks John.
Unquie1,
8000 is a safe limit for the moment. Not sure what Tomei rate there stroker kits for but i doubt i'll go past 8500 anyway.
It is a little slow getting the boost up and you make a good point about the ex housing. When the turb came back from ceramic coating the 1.00 was fitted. It was supposed to have been changed to the 0.81 before going on the engine. I will have to check that when i get back to Perth. Only got to drive it a couple of times before i got shipped out bush again :D
What cams are you using Brad?
Pretty happy so far. the old motor with 380 at the wheels was the most powerful car i'd ever been in. Now with 540 it certainly brings a smile to face. The noise that comes out of it is insane lol.
cheers
Paul
nice work, looks very similiar to mine on similiar boost ;) is 8000rpm the limit of the 2.8L kit or is this just a safe limit for the moment? is this on the 1.0 ex housing? fullboost at a fraction under 5000rpm looks like it, mine is making 18psi by 4300rpm i think from memory.
  • 1 month later...
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
