Hey guys
Last week i was speaking quickly with someone about how i can make an RB26 block stronger, we didnt get into price or anything like that though.
Ive bought another RB26 motor that over the next little while ill be building for big, big power
Who here has done the resin filled block? Any words of wisdom from those guys would be great :pirate:
Another thing thats on my mind about it - is it going to be more effective to resin fill an 05U block than rather just getting a 24U block and using that without resin?
Lastly - how much does the process cost?
Cheers guys :D
https://www.sau.com.au/forums/topic/210084-rb26-resin-filled-blocks/
Yeah, dont worry mate, the only part ill have to do with is paying the bill and driving it
But still have virtually no info on the actual process, benefits (compared to buying a 24u block), costs etc
Benefits will depend on how far you fill it. You can still street drive it if you only fill to the bottom of the water pump. If you fully fill it its only drag after that. Just make sure its washed out with acid to give a good surface for the resin to adhere to. Also depending on the product you use, you may have to line bore the block to get it all square, but that depends. Its a good idea tho if block rigidity of the lower section needs to be better. Price I cant remember what i was quoted, but i know the block is supposed to sit for a substantial time after filling.
Edited by GTR1993
Ive done a few rb blocks using Hardblok which is designed to have the same expansion rates as cast iron and is very permanent. Ive done 1/4 fills and 1/2 fills. The 1/4 fills seem fine on the street as far as cooling is concerned. The 1/2 fills have been done for the drags so I have no idea how they fair for a daily driven car but I'd imagine they would cope fine. Hardblok is just like tile cement and you mix it with water using a power drill with a paint mixer attached. I use a small funnel that I jam into water gallery holes in the top of the block then just pour it in a bit at a time and work it in with some wire. Once you've poured some into each hole you can just work it all the way around the cylinders with the wire. Its messy crap and bit of a pain to do but its not that hard to do it yourself.
when u say 1/4 or 1/2 filled, where on the block are those measurments? i.e is 1/4 filled to the bottom of the welsche plugs?
Needs to be street driven, what sort of time would you call substantial? Days/weeks/months?
Thanks for that, i wont be doing it myself though
From the 1/4fills have any of those blocks failed? I assume they're all running big power
How much power are you realistically looking at making?
On a side note.... Looks like I aint selling my gt block to anyone!!!! :D
450 awkw and ill be happy
You can bore a block 24hours after using Hardblok and use it straight after that. The 1/4 fill block runs low 11 and is daily driven. It was mainly done to stop oil getting into the water not for overall strength like the 1/2 and 3/4 fill blocks.
Cool thanks :D
When i talked to a place in Adelaide (rhemac) they liked to leave it for weeks, i looked on the net and some people like to leave it for months!
http://www.mustangsandmore.com/ubb/Forum12/HTML/008073.html
Im not sure how long it must be left tho.
A 1/4 fill is pretty much the bottom of the welsh plugs. The main reason we did this is that we found that some blocks were cracking internally between 3 and 4 where an oil gallery runs from one side of the block to the other causing oil to mix into the water.
Would this be why some rb26 blocks leak coolant out the side above the oil outlet hole?(which is between 3-4) May explain why my radiator fluid looks like the Exon Valdize shipping lane and the coolant out the side of the block.
btw. I'm not to fussed as I'm building a RB30/26 but I've seen a few rb26 motors with the leak out the side so this is quite interesting. :thumbsup:
I hope the rb30 doesn't have the same issue.....
I have seen and heard of many rb26 blocks that crack both internally and or externally which is the reason most people look for the stronger N1 blocks.
Ive only used the Hardblok product and usually leave it for a week before machining but they say it can be used after 24 hours.
As far as the rb30 blocks are concerned they dont seem to suffer from the same problem but I have heard of them cracking between 5 and 6 under extreme loads. Ive seen some guys make up a plate that bolts toward the rear of the block for added strength. I would imagine that when the rb30 block is used with a rb26 sump and adapter plate that this would add some strength to that area anyway. Ive just done a 30 block for a gtr which should push over 1000hp so I added a 1/2 fill of Hardblok for a bit more security. Being an all out drag car cooling shouldnt be an issue.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
