Nistune Powerfc Hks Fcon Haltech Ems Link Ecu Etc Real Time Road Tune And Dyno Tune Available In Sydney And Other State
Hi Toshi,
I recently bought an r33 gtst, mild mods, fmic, turbo back exhaust, CAI, boost. Just after your opinion of whether a remap or an emanage blue would be better for my application.
Also, i am currently getting around 330km from 55 litres of fuel, would your flash tune decrease fuel consumption by much?
Final question, does your remap eliminate the Rich and Retard feature of the standard ECU?
Very keen for this tune once i sort my misfire issue out.
Thanks,
Dave
Edited by Daza33
i have a remap ecu by toshi and he does a great job and would be well worth the dollars.it does elimanate rich and retard and can have ur rev limiter and top speed changed,i would advise u to get a walbro or bosch fuel pump and have it rewired to receive direct current from ur alternator so u receive a constant voltage.also make sure ur boost controller is strong and doesnt spike for best results.toshi is a very helpful guy and will help answer any questions and sort any isssues.if u have the cash id go a nistune
Hi Toshi,
Thanks,
Dave
I sent PM.
Thank you RB25 SKYLINE
Got my mates 200 tuned by Toshi.... just waiting to throw my new turbo setup in before I take my 33 to him...
I also made up some stickers for him to help spread the word.... If anyone wants one give Toshi a call.
Available in a bunch of different colours.
Edited by arrydjay
  • 5 weeks later...
heres my dyno results after a toshi tune on a r33,full exhaust,aftermarket fuel pump,FMIC.
is there any way i can get nistune with base map shipped to kl malaysia..pls pm or email me at [email protected]
will gladly provide specs later..
  • 1 month later...
R34 RB25Neo
V-Power 98
16psi
GCG hi flow turbo
Standard internals
3in exhaust + dump
stainless turbo manifold
Apexi front mount Delta type
Z32 air flow meter
Splitfire coils NGK plugs
STD injectors
Walbro fuel pump
Nistune by Toshi
277Kw 500.3FtLb torque
R33 S2
Unopened RB25 ~100,000km
Hypergear PU Highflow (non SS1)
Blitz return flow FMIC
Splitfire Coils
Metal intake with std airbox
Z32 AFM
S15 480cc injectors
Gizzmo Boost controller
Xtreme Cushion button clutch
RB25DET
18psi
GCG turbo
RB25 Standard internals
Front mount inter cooler
Z32 air flow meter
Fuel pump
269kw
R33 Series 2 5spd manual
Stock RB25det series 2 engine
-3" turbo back exhaust
-Hypergear Hiflow 21U housing (R33 turbo hiflow)
-Z32 afm
-Pod filter
-Stock injectors
-Frount mount intercooler
-wolbro fuel pump
Makes 263rwkw on 15psi
RB20 RB26 std cam shaft data
Std RB26 over lap is 0 degrees.(I think for emission control).
Std RB20 over lap is 5 degrees.
Std RB26 cam shaft cam angle ; IN 240 degrees EX 236 degrees
Std RB20 cam shaft cam angle ; IN 240 degrees EX 240 degrees
Adjust cams gear for RB20 and RB26
For make more power
Std cam shaft ; valve timing adjust to around IN 110 degrees EX 115 degrees and adjust over lap to 13-17degrees.
Hi cam shaft valve timing adjust to around IN 110degrees EX 115 and if you do not like rough idle do not adjust over lap over 20 degrees.
Valve timing is depend on hi camshaft and turbo.Find best valve timing is need many times adjust and test so adjust valve timing is take a time for hi cam shaft.
How to adjust valve timing
It is available to adjust the valve timing and change the engine out put characteristics by change the valve closing timing according to the initial value.
・ Crank pulley left turn(Advance Valve timing)→Low end boost
・ Crank pulley right turn(Delay Valve timing)→High speed gain
Hi Toshi,
If I were to send you an R33 series 1 RB25DE stock ECU, can you modify it with Nistune, to allow a Nistune tuner in victoria to tune my RB25DE+T? The Nistune website doesn't list anything for R33 RB25 and says to either use an R32 RB20DET ECU or a Z32 ECU with modifications?
Cheers, Josh
People mixed up nistune board and nistune software.
Im using nistune software for R33 ecu tune but I do not using nistune board.(Im using daughter board (impoart from Japan) with emulate)
Please read this thread.
http://www.skylinesaustralia.com/forums/topic/405546-r33-ecu-basic-dyno-tune-drive-in-drive-away-only-580-full-road-tune-from-550-include-parts/page__hl__toshi__fromsearch__1
If you want to use nistune board you need Z32 ecu or R32 ecu.
I can send Z32 ecu or R32 ecu with nistune board installed de+T data.
Price $600 include ecu.
Ah ok. It read as if you were able to now Nistune R33 ECU's. $600 plus freight for plug-and-play Z32 ECU for a R33 GTST, that any Nistune tuner can use, correct?
The approach that is taken in Japan for better responses is to change the VCT (NVCS) rpm when a bigger turbo is installed.
However, unfortunately VCT rpm is often not changed here in Australia.
On the mainline dyno, the difference can't be seen too well but on the hub dyno and on the road, there is a significant difference
It may be an idea to give it a try- change VCT rpm yourself
Good Luck
I tuned Mr David Stankowski nissan laurel RB25 DET race car last year and he is driving REPCO PRO DRIFT CHAMPIONSHIP this year.
ECU is real time tuned R33 ecu. (not Z32 with nistune board)
His car mods is FMIC , bigger fuel pump , my tuned ecu , and stock turbo!
Boost 15psi.
http://www.nissansilvia.com/forums/index.php?showtopic=518812&st=0&p=6586278&hl=david%20stankowski&fromsearch=1entry6586278
http://www.youtube.com/watch?v=Vb4kF8O531k
  • Like 1
Some JASMA muffler (made in Japan quiet muffler .eg;quiet NISMO muffler) can not make power.
Because oust side pipe is big but inside is very small for pass registration in Japan.
