Nistune Powerfc Hks Fcon Haltech Ems Link Ecu Etc Real Time Road Tune And Dyno Tune Available In Sydney And Other State
R32 GTST engine std RB20det
-3" turbo back exhaust
- Made in China turbo (I forget turbo size)
-Z32 afm
-Pod filter
-550 injectors
-Frount mount intercooler
-wolbro fuel pump
213rwkw on 15psi
People have question how much boost and how much power safe with stock internal engine.
Many Japanese tuner say RB20 around 240kw and boost 15.5psi also R33 RB25 around 260kw 15.5psi.
Safe max boost RB20 and R33 RB25 both17psi.
Because both engines piston is not strong.
Neo RB25 piston is much stronger and connecting rod is same RB26.
The difference between dyno tune and TOSHI's dyno tune and road tune.
Its very hard to explain but my customer up load to 300zx forum.
300zx customer has quite tactfully summarised what I take pride in when I tune.
Let me quote from his first hand experience
"Funnily enough my mate just bought a 2 seater and has 270 rwkw, got the sheet to prove it and mine has 250 mine feels like it pulls harder from the toshi tune than his and the curve is smoother I can tell you that the mid range in mine is light years apart from his and both have the same mods, maybe his might make a bit more up top but mine feels shitloads quicker and better to drive especially when pulling out of corners."
Basically, importance is placed on practicality. I believe in real power rather than mere numbers.
  • 5 months later...
Some people asked about silvia and also pulser NA turbo for tune.
Yes, I can tune nistune any nissan include NA turbo.
Also I can tune like a HKS bolt on turbo kit by HKS FCON .(and any piggy back or stand alone ecu)
eg: HONDA JAZZ , TOYOTA YARIS etc.
Hi everyone,
Just wanted to let you know that I've finally joined facebook!
It's still under progress but come check it out!
TOSHI TUNE
http://www.facebook.com/toshi.tune.3
Toshi planing to go to Brisbane in March.
Anybody interested in Toshi's road tune (also dyno tune)?
All Nissans include bolton turbo NISTUNE , remap ECU ,Power Fc ,HKS FCON
How to tune on road
I will fit wideband air fuel ratio meter(same dyno machine O2 sensor), and lap top computer, Gizzmo KMon Knock Monitor & Analysisor,before we leave.
While the customer is driving,I will sit in the passenger seat with my laptop.
Start with 2nd gear, winding up from 2000rpm-5000rpm to check car condition and datalog.I will make fuel and timing map then 2nd gear again to check air fuel ratio and engine knock.After making rough map on 2nd gear, we will go to freeway .With 3rd gear, we will be running on freeway from 2000rpm-3000rpm to check engine response and engine knock.Then next 3000rpm-4000rpm ,this will be repeated in increments of 1000rpm.If we find flat spot , slow response , laggy,engine knock etc I will fix and tune on freeway.
After I will drive myself for check and tune power and engine response.
If you would like to tune on dyno at 4th gear we go to dyno shop.
Take around 5-8hours.
Price $550 labur.
If you would like to road tune and dyno tune both , 1 hour dyno fee will not be included in the cost.
e-mail [email protected]
Ph 0410490049
  • 4 weeks later...
Hey Toshi, just wondering what the benefits of Nistune has over a daughterboard/chip. And what's the cheapest way to get my R32 w/RB20 tuned safely? Cheers
Chip tune and nistiune exactly same performance.
But I do not do R32 chip tune now.
Chip tune only R33 now.
R32 nistune is $950 road tune and dyno tune both.
Hi Toshi. Will you be coming to Melbourne?
Stagea s1 rs4 factory auto converted to manual and rwd. 3" turbo back, fmic, pod, bosch pump and greddy profec ii.
  • 3 weeks later...
Toshi tuned my wife's z32, and my friends z32 in March. Both very happy with the results.
He also had another go at my z32, because last time I exploded a turbo outlet coupler and could not make boost.
I have a graph from an 'experienced' tuning house on the northside of brisbane, that says 284.9rwkw at 17ish psi.
I can tell you that at 16.5psi now, Toshi's tune would destroy the dyno tune in every aspect. Response, driveablilty, idle, fuel consumption. Everything.
The car is much, much faster now on Toshi's road tune. Not even slightly interested to know how many kw it makes now.
Because faster is faster.
  • 1 month later...
Stadium Drift top 8 video clip.
Blue David Stankowskis car ecu tuned by Toshi and hypergear R33 turbo.
3rd place now!
  • 1 month later...
When are you coming back to Brisbane Toshi? I have another friend who would like a z32 tuned.
  • 4 weeks later...
Pro drift battle top 4 video clip.
David Stankowskis car (blue car ) mods is RB30 engine RB25 head , R32 ecu (tuned by me), hypergear R33 turbo.
Hey Toshi,
I have a r33 skyline I need tuned mid to late this month, I've been recommended to go to you, it's mildly modified 90,000kms
Front facing plenum
FMIC
Garret 3582
External gate
3" turbo back
1000cc bosch top feeds
Billet rail
Tomei reg
Z32 AFM
r32 nistune ecu
Walbro pump
+ a few bits n pieces
I already have a r32 ecu with nistune daughter board fitted,ready to swap on arrival to tune, as I also have to fit my fuel system (excluding pump) and afm (made up a quick release plug to suit both already so it's a simple plug in arangment)
If you could get back to me with a message regarding a rough price that would be great and il try n work out a day that suits is both,
Cheers,
Gav.
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
    • That is porn and I wish I could do it easily on my streeter.
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
