Nistune Powerfc Hks Fcon Haltech Ems Link Ecu Etc Real Time Road Tune And Dyno Tune Available In Sydney And Other State
I'm also looking at getting a tune checked/done
My r32 gtst
mods are
Rb20det
Fmic
Rs*r 3.75"
Coil packs
Pod filter
New clutch (heavy duty)
Already has a remapped ecu
How much am I roughly looking at?
Thanks.
  • 3 months later...
Hi Toshi,
I know I asked ages ago, but I'm starting to more seriously look at getting this done - am saving now.
My car is:
R33 GTST S1
stock turbo, stock injectors
Apexi AVCR
3" turbo-back exhaust
FMIC
I'd need the Z32 ECU with Nistune board supplied - so basically I'd turn up with my car as is, and get the ECU replaced and tuned by you - how much would that be in total so I know how much I need to have in cash?
Thanks mate!
  • 4 weeks later...
Toshi,
I want a Z32 Nistune ECU with a pre-loaded map for:
R33 Gts-t Manual
Full 3" turbo back
R34 SMIC
GT-R Fuel pump
Stock tubro, stock injectors.
Can you quote me for supply of this? ETA if I order?
Would I need to get a dyno tune to check AFR's etc after fitting?
  • 3 months later...
I am often asked how much power increase about E85 TUNE.
Power is around 30kw more than 98 octane fuel.
I recommend Bosch 1000cc injector because much better spray than hiflow injector.
  • 4 months later...
Hey toshi quick qoute mate
R33 s1.5
Hypergear atr43ss2 turbo
Fmic
750cc bosch injectors
255lph walbro fuel pump
Greddy style plennum with std throttle body
Z32 afm
3inch turbo back exhaust
Power fc
May have to get the plennum and injectors fitted
Edited by cav33r
  • Like 1
Hi cav33r
Price $550 road tune $600 dyno tune only $700 dyno tune and road tune both.
Hi soulfood187
If come weekday you can come any time.
  • 1 year later...
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
