Nistune Powerfc Hks Fcon Haltech Ems Link Ecu Etc Real Time Road Tune And Dyno Tune Available In Sydney And Other State
Just had my Stagea ecu done by Toshi
can confirm that it works, for sure
interstate job, so we havent met face to face nor has he seen the car
he got in an adapter, a large ecu chip that he did his majik on, and arranged (for me, so happy!) to have the adapter properly installed when my local mojo's didnt want to do it.
got the ecu back in time (today) for my dyno tune of safc/sitc tomorrow.
feels good to drive atm, the retune on dyno of the piggybacks will make it awesome Im sure
Hey Toshi.
I live in Sydney and have an R34 GTT.
Its stock but will a remap have any benifits?
And how much?
Thanks mate.
Dave
Edited by wisey18
Hi Dave
How is muffler?
All stock?
I think you need boost controller.
Normaly about 15kw-20kw more than std ecu.
You will get 185kw-200kw at 10-13psi.
Thank you
Hey Toshi.
And how much?
Thanks mate.
Dave
Hi Dave
How is muffler?
All stock?
Normaly about 15kw more than std ecu.
Thank you
Muffler is stock.
Havn't got a boost controller yet but will be getting one.
OK
Please fit boost controller.
If you fit turbo back muffler and hi flow cat you are able to get around 195kw at 10psi-11psi.
Muffler is stock.
hey toshi
i have an rb25det r33 skyline series 1 with following mods going in next week
Garrett GT30R (GT30/40), custom top mount manifold, dump pipe and ext wastegate
sard fuel preasure regulator
sard 550cc injectors
z32 afm
car already contains front mount, full exhaust , bigger fuel pump.
all i am mising is a good tune..can you do this or would i best off using a apexi power fc
i am located in sydney, parramatta. cheers
Yes, I am able to remap.
Cost road tune$550.
RB25DET std engin is up to 370, 380 hp (about 280KW) safe.
If you want to more power I think you need change after market engine parts (piston , crank shaft etc).
If you change to smaller turbo you do not need change injector. (RB25det injecter is up to 360 370 hp max)
Is this race car?
Toshi
hey toshi
z32 afm
no it is not a race car just street. i dont want to rebuild engine yet so i will be happy for about 260kw can you achive this?. i want the boost to come on early so not much lag can you do tune for this? pm me your mobile number if you can thanks toshi
hi toshi
i've got r33 s1 wit the following mods
front mount.boost controller.turbo back exhuast.safcii.splitfires coils.fuel pump.
gt30/76 and the only problems is its an auto.can you do anything?cheers tony
Yes, I can remap.
How is AFM?
Is this Z32?
hi toshi
  • 4 weeks later...
R34 ECU map
R34 can not boosted up more than around 12psi.
Because ignition timing will retard around 12psi.
Its same R33.
Also if you will boosted up around 12psi , engine will ping at around 3600-4400rpm.
Because R34 std ecu ignition map is 3600-4400rpm very hi ignition timing for Australia fuel.
  • 4 weeks later...
Hi Toshi,
Since the Brisbane trip is a bit complicated with needing to do cars during the work week and you needing to fly up here. What other options do we have? ie. retune by mail?
I need some sort of retune as my car pings if I apply throttle hard between 3500 and 4500 rpm.
Running 10 psi, full exhaust, R34 intercooler, filter and walbro pump.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
