Nistune Powerfc Hks Fcon Haltech Ems Link Ecu Etc Real Time Road Tune And Dyno Tune Available In Sydney And Other State
I got my ecu remapped by toshi and the results are amazing.
Thanks Toshi.
Thank you Bahamasky.
He is living over sea and his car is fitting big turbo.
Mods:
FMIC
GREDDY PLENUM INTAKE
Q45 THROTTLE BODY
550CC INJECTORS
TOP MOUNT GT35R GARRETT TURBO
ACT STAGE THREE CLUTCH
TAIL BOV AND WASTGATE
STRAIGHT CATBACK EXHAUST
NISMO REGULATOR
HKS CONE FILTER
Im sorry I did not get your e-mail.
Toshi can u give ur email address i'll send it again, coz i sent u a long email before explaining the problems it was on ur profile where it says send email i sent it thru that plz check ur SPAM or junk email folder in hotmail or yahoo, gmail etc. it could be in there i cant send PMs reason not enuf posts.
thanks
Edited by sidewinder11
thanks
My e-mail address and phone number is first of this thread.
[email protected]
  • 3 weeks later...
Im starting Power FC road tune by fc data logit (laptop computer).
Price $400
If your power fc is not tune yet , try my road tune.
If you are not happy with the performance, I will not charge.
0410490049
[email protected]
I sent remap chip to epigram and he got 265.4 RWHP or 197.98 RWKW (auto mission) on 98 octane.
His mods
Series 1 2 door R33 AUTOMAGIC
80k std RB25DET
std turbo
std injectors
std manifolds (in & ex)
Monsta FMIC
Bosch 040 fuel pump
Toshi Kubota modified and remapped std ECU
Tomei adjustable FPR set to 45psi@idle
std coils
NGK BKR5EYA special anti fouling plugs gapped to 0.8mm (no misfires!)
adjustable boost bleed valve set to max 12psi
std auto
std dif
http://www.skylinesaustralia.com/forums/Au...0&start=220
Thank you
  • 1 month later...
hey toshi
got a auto s1 stagea
should i get a shift kit fitted before a remap?
You do not need shift kit.
Hi Toshi
I'm keen for a remap.
2002 R34 GTT Auto
3 inch turbo back exhaust with hi flow cat
hypergear hi flowed turbo
cold air intake with K&N pod
Std injectors and fuel pump
Std intercooler (which i think is probably where the bottle neck is going to come)
I'd be keen for 220- 240rwkw, as i don't want to push the standard internals, any suggestions where to go from here?
I have my Toshi remapped ECU in my R33 Auto. I live n Brisbane, this was all done via express post and my dyno shop. It is the single best upgrade I have given my Skylne.
Performance is remarkable. Power increase, fuel economy better. AFR is steady, I dyno'd
my car and results are amazing! This guy knows his stuff!
My car is transformed, excellent service too, pleasure to deal with.
Highly recommended.
Hi Toshi
2002 R34 GTT Auto
I sent PM.
Thank you
Highly recommended.
Thank you 1C3B3RG.
if you have any further queries, please feel free to contact me anytime.
I sent PM.
Thank you
Hi
I can't reply to your PM for some idiotic reason, because i am new here and haven't posted 10 times yet. I also can't message the administrators and ask them why, for the same reason.
Any way, yes there is a dyno shop nearby, but i don't know about the soldering part. How much soldering is there? I thought it would just plug in, in place of the old ecu?
What would need to be tuned on the dyno exactly,and would the people running it have the software to do it?
Regards
Nick.
hi, my r33 has been tuned by "car station" in japan.
Ive opened up the ecu box and there is a socket with a removable chip on the board.
If I changed my setup eg AFM and injectors could you supply a new chip for my box to run the new gear?
thanks
thanks
Yes,Im able to supply new chip.
  • 1 month later...
I have a question.
If i already have the nistune board installed, and the nistune software, is it possible to just email you the BIN file, you do the adjustments and email it back and i burn it too the chip? This would save sending the entire ECU to you?
I have a question.
If R32 or 34 it is possible.
But cost more.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
