5psi under 4000 in 1st and 2nd gear. then 7spi.
turbos is same as a r33 gtst series 2 (ie plastic front wheel and ceramic rear) nice early spoolup but no good for more than 12psi.
assuming you have a series 1 that is
Duncan do you know same info for series 2?
Same applies for the S2. I recommend doing the Boost Solenoid Trick so it boost at 7psi all the time rather then the 2 stage boost, or get yourself a Turbotech Manual Boost Controller and a Boost Gauge installed and run 10psi all the time. DO NOT GO OVER 14psi or you can say bye bye to your turbo.
12psi boost really livens them up nicely. chirps second now.
they are damn heavy to start with
This is with a drain-pipe out the back, a pasta strainer on the intake and a bar fridge behind the front bar of course? :thumbsup:
lol yes, no, no. but it does reallty help. (and none of that auto junk either). But we both know yours makes more peak power than mine.
at least until I can rev it over 4500 at last (needs a proper tune). My peak power was 111awkw lol. midrange is swoit though.
Yeah I did the 'ground the solenoid' mod, works well and tends to surprise people in traffic when the boost comes on. :thumbsup:
Makes for a perfectly flat boost line on the chart...
AFR's are scary though
Thanks, so is the S2 turbo the same as the S1?
Yeah I did the 'ground the solenoid' mod, works well and tends to surprise people in traffic when the boost comes on. :(
Xmetal did you have any other mods when you did this dyno run (intake/exhaust?) And I don't know much about tuning but is that jump to 14.5:1 just above 120k's there what they call R&R (rich & retard?)
