Wierdest thing happens in my car
Sometimes after booting the car a bit i notice the back wiper/washer assembly appears to have leaked out water.
And dosent seem to happen (or leak as much) if i drive the car around easily.
WTF
Does anyone have any ideas?
Strangest issue...
https://www.sau.com.au/forums/topic/210115-rear-wiperwasher-leaking-h20/
The rear wiper does have that squirt water thingy which connects to the plastic water tank in front of your car so maybe the hose is damaged/wornout. Example, like raining and water entering through the sunroof aka seal is bad.
my 32 GTR does this too. only after hard driving, or driving at the track. the rear washer jet leaks out water all over the rear screen. I haven't driven the car for ages so I haven't looked into it but I have NFI why it started happening, it never used to do it. :domokun: farken annoying too.
my 32 GTR does this too. only after hard driving, or driving at the track. the rear washer jet leaks out water all over the rear screen. I haven't driven the car for ages so I haven't looked into it but I have NFI why it started happening, it never used to do it. :) farken annoying too.
yeah exactly same as my problem
whats the deal
and yes it is really farken annoying
If you mean it leaks on the outside of the windscreen its probably due to...
No pump(or centrifugal type booster pump) mounted up the back, relying on pressure from front pump, therefore under 'fun-time' water surges back along the lines(always primed) unrestricted = inertia pumping the water.
Did I make sense? :thumbsup:
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
