mate you get what you pay for.... in the case of china/korea/asian turbos... you will get a cjheap turbo that makes som power, but doesnt spool as early, or make as muich power as a well made "name" brand turbo... its not to say the cheaper option is totally shit... but there are better options out there for a few bucks more.
check out the garret range, or even second hand HSK turbos... a 2350 would be perfect for what you want.. it will make 230 rwkw and have awesome response for the street.
this just in:
RB20- Standard Internals
Hyper Gear HR43 High Flow Turbo
High Mount Manifold
External 38mm Wastegate, Screamer
Z32 AFM
550cc Injectors
Speed Lab Remap ECU
Running 19psi made 245 rwkw
Edited by joeleo87
dmac_25 has just finished putting on a TR43
I went for a drive with it on 10psi and it goes alright - pulls hard from like 4,500 all the way to red line easilt
Have to see how it goes once its tuned - but PM him if you want more details
Standard RB20 with FMIC, GTR pump, turbo back exhaust and CEF11E remap (for bigger injectors and Z32 AFM) but they weren't on the car at the time
It looks neat though, you can't tell there is an after market turbo on there - retains all the stock intercooler piping etc
untuned on the RB20 with exhaust and cooler it came on full boost about 4,500rpm I think it was
Yep it is starts spooling at bout 3 hits 10psi about 4-5k rpm and pulls like a bitch all the way to the limiter
funny Simon I don't remember reading anything about you being disappointed
with the power fig and response when yopu fitted it up
:teehee:
guess sometimes you gotta keep your thoughts to yourself lol
2530 will eat a tr43 response wise and only make alittle less power 230ish
fullboost by 3,500 and would pull all the way to redline
I though that was alittle laggy cant imagine what 4,500rpm full boost would be like on a 20
I'd want 260rwkw min for that sort of lag
i mentioned several times that i was never very happy with the responce on an rb20, maybe try reading harder. Power was good tho.
now that i have a good turbo... its easy to compare it to the bad ones ')
:whistling:
Simon: First of all I don't remember that we sold you a TR43 high flowed version or if you were one of our customer at all.
We are not KKR so If you had bad experiences from other turbo suppliers please chase up with them instead.
The TR43 Hi flowed turbo developed is a High boost High Efficiency project built with 360 degrees trust bearing and a lot stronger shaft.
Supra_R32 on this forum has made 245RWKWs at 18PSI full boost at 4300 RPM with a RB20 we have made 280RWKWs with this turbo on a 1.8L CA18det !!! .
Even for a Standard TR43 we've made 190RWKWs on a RB20det with 10PSI of boost with factory every thing.
Turbo is just a compressor, If you've bought this turbo and not making power, then I suggest you to check your tunning as well as other supporting mods.
Edited by hypergear
