Item: Customized R34 Sidemount Intercooler to fit r32
Condition: Great condition, no leaks
Price: $250 $220 + delivery
To Fit: r32 gtst
Contact: PM or reply in thread
Comments:
Reason for sale; upgraded to an ARC SMIC
Up for sale is my R34 SMIC which has been professionally customized to fit r32 gtst.
Basically a direct bolt-on, just remove your standard smic and bolt it on!
Being 54% larger than the R32 smic and rated to about 220kw atw; the smic is a low cost, great upgrade to any r32.
Advantages;
- No turbo lag caused from a large FMIC, throttle response is exactly the same!
- Sits in the same place your standard SMIC is, forcing air through the intercooler.
- No hole cutting for intercooler piping, making it a legal modification for your car.
- No cop attention, hidden away and no troubles when running an airpod
- No intercooler blocking radiator or any messing frontbar customization to make it fit.
Results;
To eliminate any variables, Dyno run was done before SMIC install and straight after SMIC install.
*cannot guarantee you will get the same power increase, although another person who did the same modification also had a power increase of 10kw atw
Pictures:
Any questions feel free to post :domokun:
Cheers
Patrick
https://www.sau.com.au/forums/topic/210123-r34-smic-direct-fit-for-r32/
what's the width/depth of the cooler core?
R32
Length: 205mm Height: 190mm Width: 60mm Volume: 2337cm^3
R34
Length: 205mm Height: 220mm Width: 80mm Volume: 3608cm^3
Volume difference of 1271cm^3
Therefore;
R34 smic is 54% larger than the R32 smic (relative to the r32 cooler)
Price lowered :)
Even if you buy a r34 smic for $150 it will cost you over $50 to get it customized for r32. Not to mention the time required to find a welder :)
Great mod for r32's
bump :banana:
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
