Hi all I've been a lurker for quite a while now , but I do have a question. I'm in Sydney at the moment for a few days. and I'm in the market for a R33 Sedan. Have found one here and will get out at some time for a look. So..... the question is If I buy out of SA will the car need to get inspected, and what should I expect Has any body gone this route? Thanks for the feed back
Cheers Paul
If the car already has rego in another state you bring it back and it just gets an ID check to make sure its not stolen etc and as long as it doesnt have anything obviously defectable it ought to be fine...
2nd that!
All obvious mods remove, and you'll be fine.
I bought a 32 gtr in dec from melb, heaps of mods done.
Made it look stock, raised coilovers etc, remove gauges, pfc controller, boost etc.
All good, extremely worrying at the time but all i needed was Vin stamped.
Jason
That is not right the car must have a Complince plate if it has not got one you will have to have a full check over if it has all you need is a id check
If its got rego in another state, then it must already have a compliance plate.
Take the car to the Sturt Vehicle Inspection Station if you can, if the car has a few mods. They're not as anal as Regency.
I've gotta do the same for my Stagea, so I'll be going to the Sturt inspection station near the Sturt/Darlington Police Station.
a couple months ago i bought my 32 from VIC..it had vic plates and vic rego so all i had to do was take it to a cop shop, i went to sturt rd cop shop, and just get and id check. However if there are obvious defects such as gauges, too low, tint too dark like mine had they'll tell you to fix them and come back. However tif they believe the car needs to go over the pits coz it has alot of work done to it they will then send u to regency which isnt nice at all lol
good luck man
No just because it has rego and it maybe complied it still has to have a compliance plate on the back of the eng bay of on the inside of the drivers door if it does not have that plate YOU will have to have a full check over
If it has the compliance plate, its complied ... thats what I meant. Please learn to read. :laughing-smiley-014:
I'd rather the car get the full check over. I don't fancy a cop lubing me up :laughing-smiley-014:
Edited by RubyRS4
Just because it has a compliance and it has been complied in another state that does not mean that it will get though here with out a full check SA still has to do a full check on "Imports" that come into SA .And he was talking about a R33If its got rego in another state, then it must already have a compliance plate.A car can have rego in any state and not be issued with a compliance plate
"QUOTE If its got rego in another state, then it must already have a compliance plate. your QUOTE RubyR4"
Edited by puresx
Yeah ... err ... thats what I was saying in the first place :) Glad you agree with me :laughing-smiley-014:
Anyway ... back on topic. Take the car to the Sturt Inspection Station next door to the cop shop and you'll be better off there than Regency, who have a larger capacity to go right thru your car should they deem to.
Edited by RubyRS4
Hey boys now I'm confused.....my thoughts were that you can't get rego in any state without a compliance plate fitted & sighted by an official.
If that is true and this vehicle in question has interstate rego then I would assume that it would have to have a compliance plate fitted.
If that is also the case then a Sturt inspection for eng & vin is all you'll need (Wed & Thur 11am - 3pm & no appointment required).....just make sure there aren't any obvious things like dark tint on front doors, too low, tyres sticking out of guards, pods OK but must be secured, exh hanging on the ground, etc
They won't check ECU, turbos, fmic (unless 1/2 your front bar is cut away) and if exh is loud just idle into the shed.
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
