when i lost my license they took it destroyed it then after the months i got a new one with an X on it which means special circumstances...in my case i was only allowed 1 passenger for a year.....but as i wasnt on full license im not sure if it is the same......
  • Replies 50
did u have any trouble with the passenger restrictions rule...I;ve got it but i never handed in my license and they never said anything so i dont have that x on it..
Originally posted by pushead
man, i nearly lost my licence too.. lost all 12 points vicroad sent me 2 options either loose it for 3 months or be good behaviour for 1 year.. took the 1 year :P
Pushead, don't know how you lost so many points... the way you drive, they must have been giving points for going too slow:shake:
well i did have problems because sometimes i needed to carry more then person :D
They shouldn't destroy your license, when you hand it in they send it back out to you in the mail. i know because i got mine back on monday after 1 month suspension.
it depends on the circumstances, i had a 1 month suspension and i had to go in to vic roads and get a new license made up and a new photo taken because of the X on my license which was mentioned previously. this x stayed on mine for a year then i got another new one with no X.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
