Hi all
i purchased a new airbox for my rb25det http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...sid=p2759.l1259 i have installed it three times and every time its on the car the turbo dosnt want to come onto boost it trys but nothing happens the bov makes a muffled sound and the car just accelrates slowly but unwillinglly
very frustrated been working on it four 6 hours now i had to disconnect the black cannister near the air con condensor and remove the intercooler piping other than that everything is untouched.
thanks in advance
https://www.sau.com.au/forums/topic/210184-airbox/
Hehehe :teehee:
Is there any holes so the air filter can get air ? maybe you sealed it up so tight there is no air for it to suck ?
air filter pipe kinked at all ?
take some pics of it installed and post em up ?
cheers for takin the neon comment like that, made my day :P
lol i didnt put the neon in maybe thats my problem
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3716258
ok guys the rubber adapter was split problem at bottom replaced it, f it runs to boost ok now but is missing at top of rpm you rekon sumthing simple is going on or have a broken something? lis is still off
Edited by stavros01
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3716452
you see... this is why I carry on about using the stock air box.
look how much time/money you have spent.
How much it's giving you the shits.
and you've gone Backwards in performance in comparison to an exposed pod filter, and even further backwards compared to a stock air box.
there are at least 3 stock airbox with snorkle and panel filter for sale on these forums for an R33 GTST for $50.
If you must keep it, then I'd suggest removing the partition and going for another drive (how many hours to do that?).
if there are no problems high in the rev range, then you know that the partition is causing some sort of problem.
be it not enough air due to no cai (Cold Air Induction) or perhaps it is too tight around the rubber intake pipe that goes from pod to turbo and is actually crimping it a little causing a restriction in air.
perhaps due to no air feed (cai), the rubber pipe between turbo and pod is being sucked closed..
who knows..
so what are you going to do?
spend another x hours to diagnose and possibly fix it but still be left with a system that has no air feed?
or spend less time and $50 to get the stock air box and sort it out properly.
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3716538
thanks guys im going to go to stock air box and see what happens it came with the pod when i bought it all i was trying to do is keep the hot air from the motor, away from the intake seemed simple enough (sigh) hopefully nothings been changed in there to stop it fitting
fast responses support is fantastic here
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3716973
wen i get my car back ill show u out it should be set up properly, you should always stick to the OEM airbox unless you can supply a proper CAI(cold air intake) for your enclosed POD, otherwise its either A) sucking hot air which is useless or B) sucking no air cuz theres no air feed.
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3717113
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
