Hi all
i purchased a new airbox for my rb25det http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...sid=p2759.l1259 i have installed it three times and every time its on the car the turbo dosnt want to come onto boost it trys but nothing happens the bov makes a muffled sound and the car just accelrates slowly but unwillinglly
very frustrated been working on it four 6 hours now i had to disconnect the black cannister near the air con condensor and remove the intercooler piping other than that everything is untouched.
thanks in advance
https://www.sau.com.au/forums/topic/210184-airbox/
Hehehe :teehee:
Is there any holes so the air filter can get air ? maybe you sealed it up so tight there is no air for it to suck ?
air filter pipe kinked at all ?
take some pics of it installed and post em up ?
cheers for takin the neon comment like that, made my day :P
lol i didnt put the neon in maybe thats my problem
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3716258
ok guys the rubber adapter was split problem at bottom replaced it, f it runs to boost ok now but is missing at top of rpm you rekon sumthing simple is going on or have a broken something? lis is still off
Edited by stavros01
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3716452
you see... this is why I carry on about using the stock air box.
look how much time/money you have spent.
How much it's giving you the shits.
and you've gone Backwards in performance in comparison to an exposed pod filter, and even further backwards compared to a stock air box.
there are at least 3 stock airbox with snorkle and panel filter for sale on these forums for an R33 GTST for $50.
If you must keep it, then I'd suggest removing the partition and going for another drive (how many hours to do that?).
if there are no problems high in the rev range, then you know that the partition is causing some sort of problem.
be it not enough air due to no cai (Cold Air Induction) or perhaps it is too tight around the rubber intake pipe that goes from pod to turbo and is actually crimping it a little causing a restriction in air.
perhaps due to no air feed (cai), the rubber pipe between turbo and pod is being sucked closed..
who knows..
so what are you going to do?
spend another x hours to diagnose and possibly fix it but still be left with a system that has no air feed?
or spend less time and $50 to get the stock air box and sort it out properly.
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3716538
thanks guys im going to go to stock air box and see what happens it came with the pod when i bought it all i was trying to do is keep the hot air from the motor, away from the intake seemed simple enough (sigh) hopefully nothings been changed in there to stop it fitting
fast responses support is fantastic here
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3716973
wen i get my car back ill show u out it should be set up properly, you should always stick to the OEM airbox unless you can supply a proper CAI(cold air intake) for your enclosed POD, otherwise its either A) sucking hot air which is useless or B) sucking no air cuz theres no air feed.
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3717113
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
