Hi all
i purchased a new airbox for my rb25det http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...sid=p2759.l1259 i have installed it three times and every time its on the car the turbo dosnt want to come onto boost it trys but nothing happens the bov makes a muffled sound and the car just accelrates slowly but unwillinglly
very frustrated been working on it four 6 hours now i had to disconnect the black cannister near the air con condensor and remove the intercooler piping other than that everything is untouched.
thanks in advance
https://www.sau.com.au/forums/topic/210184-airbox/
Hehehe :teehee:
Is there any holes so the air filter can get air ? maybe you sealed it up so tight there is no air for it to suck ?
air filter pipe kinked at all ?
take some pics of it installed and post em up ?
cheers for takin the neon comment like that, made my day :P
lol i didnt put the neon in maybe thats my problem
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3716258
ok guys the rubber adapter was split problem at bottom replaced it, f it runs to boost ok now but is missing at top of rpm you rekon sumthing simple is going on or have a broken something? lis is still off
Edited by stavros01
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3716452
you see... this is why I carry on about using the stock air box.
look how much time/money you have spent.
How much it's giving you the shits.
and you've gone Backwards in performance in comparison to an exposed pod filter, and even further backwards compared to a stock air box.
there are at least 3 stock airbox with snorkle and panel filter for sale on these forums for an R33 GTST for $50.
If you must keep it, then I'd suggest removing the partition and going for another drive (how many hours to do that?).
if there are no problems high in the rev range, then you know that the partition is causing some sort of problem.
be it not enough air due to no cai (Cold Air Induction) or perhaps it is too tight around the rubber intake pipe that goes from pod to turbo and is actually crimping it a little causing a restriction in air.
perhaps due to no air feed (cai), the rubber pipe between turbo and pod is being sucked closed..
who knows..
so what are you going to do?
spend another x hours to diagnose and possibly fix it but still be left with a system that has no air feed?
or spend less time and $50 to get the stock air box and sort it out properly.
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3716538
thanks guys im going to go to stock air box and see what happens it came with the pod when i bought it all i was trying to do is keep the hot air from the motor, away from the intake seemed simple enough (sigh) hopefully nothings been changed in there to stop it fitting
fast responses support is fantastic here
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3716973
wen i get my car back ill show u out it should be set up properly, you should always stick to the OEM airbox unless you can supply a proper CAI(cold air intake) for your enclosed POD, otherwise its either A) sucking hot air which is useless or B) sucking no air cuz theres no air feed.
https://www.sau.com.au/forums/topic/210184-airbox/#findComment-3717113
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
